Results 1 to 8 of 8
Thread: Hayward/Goldline T-CELL-15 fitting/thread size
    Sep 2009
    Madison, AL (north AL)
    77
    Can anyone tell me what size are the threaded fittings on this stupid salt cell? I can say that they're not a standard 2" or 1.5" pvc union. I was going to use some sort of pvc fitting to plug one end so I can turn it upright and fill with acid to clean it. I'll be danged if I can figure out what fits that thing. Maybe I'm overlooking something obvious, but I can't find a standard pvc adapter to fit it.
    Does it come with its own unions for installation? I removed the cell from the plumbing, and the remaining portion of each union is of course still on each side of the pipe.
    I've seen the custom end cap that Goldline makes for it, but I'm not paying $35+ when I should be able to easily rig up my own for < $10 -- unless of course they've created some custom, non-standard fitting.
    Phillip
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Hayward/Goldline T-CELL-15 fitting/thread size
    I don't know what thread they use but you could just use a 2" winterizing plug like this to plug up the end and accomplish the same thing.
    Mark
    Mar 2009
    Huntsville, AL
    156
    Hi Phillip,
    I'm not an expert on this stuff, but I did some digging around and found that it is a 2" fitting with a buttress thread - probably won't find it at Home Depot. If you need it, google GLX-CELL-UNION and several sources will come up. Poolsonly.com had a good description of what is in their kit. I have never bought from them, so can't vouch for their service.
    If you just need to clean your cell, the plug Mark described is a much cheaper way to go.
    Good luck,
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Sep 2009
    77
    Thanks, you are dead on. Here's the response I just got from Hayward's customer support. A "patented thread". That's about the stupidest thing I've ever heard. Translation: the consumer has to pay triple for what could have been a standard FPT pipe thread. That tells me alot about Hayward/Goldline.
    "The cell unions are a patented thread that are only manufactured by Goldline Controls. The part number for the unions are GLX-CELL-UNION."
    JoshU's Avatar
    New Orleans, LA
    543
    Goldline/Hayward does produce a cell cleaning stand. The part # is GLX-CELL-STAND.
    - Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Aug 2010
    Columbia, SC
    96
    I know this is an old thread but...
    I am looking for the opposite side of the union to be able to connect where the Tcell connects and extend the plumbing. Does anyone know if this is available?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    38,521
    There are winterized "blank" cells that could work for your purpose: GLX-CELL-PIPE
    Aug 2010
    Columbia, SC
    96
    I wonder if that is a standard 2" pipe? what I need is just one of the fittings off of the end of this blank.
