Results 1 to 13 of 13
Thread: Getting some algae bloom with numbers
    Fayetteville, Arkansas
    220
    Have been following the charts and readings carefully, however I'm getting some algae.
    Here are this evening's numbers for your thoughts:
    FC 3.2
    CC 0
    Ph 7.2
    CH (vinyl)
    TA 90
    CYA 30
    Using Ben's chart - I should maintain a min of 3.2 FC and max of 6.0 ppm and shock level of 15 ppm.
    I think I'll up the CYA to at least 40 and then edge the FC closer to a 5 or 6 maintenance level. BTW, water
    clarity is very clear at the deep end. Air temps are in the low 90's, sorry no temp of the water (can't find the
    thermometer for the empty bleach bottles) !!
    Am I on track?
    Hope everyone's summer is going great and you get to spend some time in your oasis this week-end !!
    20x40 30,000 gal IG Liner, Pentair II Sand
    Arizona
    924
    If it's algae, then I would bring it up to shock level.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    30,426
    Ranger,
    If you have algae, you need to shock your pool. Bring the Cl up to the approprate shock level and keep it there until the algae is gone and your pool is pristine. Only then should you lower the Cl to maintenance levels.
    Don't play patty-cake with an algae bloom...hit it in the head with a brick.
    220
    Ok - got my brick in hand and headed out to the pool to kick some algae arse.
    30,426
    Quote Originally Posted by Rangerman
    I can hear the little buggers pleading your forgiveness all the way down here in NC......show no mercy!!
    220
    The deed is done ....
    Mar 2007
    San Rafael, CA USA
    12,082
    What kind of algae did you get? Did the water just start to get dull or cloudy (as usually happens when green algae starts) or did you see some yellow/brown dust like substance growing in the shady area of the pool (which could be yellow/mustard algae that needs more chlorine to keep away)? Or was it something like black spots on the pool surface (possibly black algae)? Was there any possibility that the chlorine level dipped low even for a short while? Could the algae have been pollen instead? Is there poor circulation in the area where the algae occurred?
    Glad your quick attack took care of the problem, but it would be good to know more details so we can adjust recommendations if needed.
    Richard
    220
    Yes, the water was dull and lacked the sparkle it had. I suspect the FC level dropped too low for a long enough period to allow its foothold. I had been trying to keep the FC level at 3ppm with the CYA reading 40. However, we have had a lot of rain and evaporation too - up and down syndrome. My CYA level had been lowered due to the required refilling. The pool is 30,000 gal with four returns, two skimmers. The green stuff was widespread throughout the pool, primarily on the floor.
    So - last night I shocked to 15ppm. This morning the pool looks much better. But I had vacuumed the stuff away too. I don't like manual vacuuming - but in this case I did. Manual vacuuming is too much like work for me. Today I'll get a couple of new sections of hose and then take 'em all apart to change up the 'memory' of the line. Noticed my vac was partial to the deep end of the pool.
    Thanks for your help Richard . . . have a good week-end.
    30,426
    Rangerman,
    Just a reminder from my previous post............
    Bring the Cl up to the appropriate shock level and keep it there until the algae is gone and your pool is pristine. Only then should you lower the Cl to maintenance levels.
    I'll bet your Cl was below 10ppm this AM. Bring it back up to fifteen at least tonight.....Then check again in the AM. One dose rarely clears a pool completely because the shock dose of chlorine is consumed so rapidly.
    220
    Rangerman,
    You bet I will . . . not going to let that happen again.
    220
    Rangerman,
    Tested the water this evening and I was surprised the FC was still at 15 for shocking. However the Ph went from 7.2 to 7.8. Is this to be expected with the addition of that much liquid chlorine? I just thought the water was clear until I shocked it. Now it really sparkles. Is it possible that I was headed for problems even with the Ph at 7.6 the other day thinking the high Ph was the cause of the dulling?
    PH readings are not reliable at high chlorine levels. Wait till the chlorine comes down under 10 and test your PH again.
    30,426
    Very possible. It is a natural tendency to stop the Cl once you see improvement. Keeping the Cl at high levels for the "finishing touch" to your pool water is a very rewarding experience. Now you can let your Cl drift down to maintenance level and your pool will absolutely sparkle all Summer....Nice work!!!
