Results 1 to 7 of 7
Thread: Cleaning phosphorescence off travertine
    Hi,
    My in-ground pool is 5 yrs old and the travertine coping and slate walls have a milkiness to them due to calcium leeching thru the materials.
    Is a dilute muriatic the way to clean it?
    What concentration and what contact time?
    Bob
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    30,403
    Re: Cleaning phosphorescence off travertine
    Muriatic is the answer.
    The strength needed can vary so you need to use just enough to have the desired effect.
    I'd suggest starting with a 5:1 (water/31% muriatic) and if it foams up when applied.....that's good enough.
    If it does not foam, slowly increase the strength until it does.
    Dave!
    Thanks for quick reply - to the point of foaming - got it.
    Thanks As Always!
    Bob
    South Central NJ
    3,192
    Start weaker (say 10-1 water acid) and gradually get to the needed strength.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2007
    Rockville, CA
    99
    Do you simply wipe it with the solution and rag then rinse with clean water? Is there a sensible contact time? Any problem with allowing the solution to drip into the pool? I have often wondered whether my high CH/scaling had anything to do with degradation of travertine coping. Don't contractors use muriatic acid to expose aggregate in concrete, so would I be inviting problems to the pool deck?
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    South Central NJ
    3,192
    After brushing it, rinse liberally. Sprinkle some baking soda over the affected area, wait a couple minutes and rinse liberally. Repeat 2 more times, three minutes or more per. That should neutralize and wash away any residual.
    Scott
    30,403
    You can be as cautious as you are comfortable with. My experience has been that simply rinsing the mixture off the surface stops the process dead in it's tracks with no further degradation of the masonry.
    I have also tried a 10:1 mixture to start but never got a reaction (foaming) until I concentrated to about 3:1. I'm not saying you won't get a reaction prior to that....I've just never seen it.
    If you use a rag, the rag will probably be damaged/eaten up by the muriatic. You can get an acid brush at home depot/lowes that will not react to the acid. (and it's easier to remove the calcium)
    Use common sense. Full strength muriatic will damage a lot of stuff. Diluted properly, it is easy to control. It will have no effect dripping into your pool.
