Thread: Hayward cartridge filter tie rod
    Hi, I was curious to see if this has happened to any other pool owners that own a Hayward cartridge filter. The filter is approximately 3 and a half years old. Over the past year, the tie rod has become very rusty. Any explanation as to how this could have happened?
    Here is a link to the manual - ... ual135.pdf
    All thoughts would be appreciated. Thanks.
    Mar 2007
    Coastalish 'down easter'
    Re: Hayward cartridge filter tie rod
    Acid bath!
    Has your pH dropped below 7.0 for any extended period? (usually trichlor pucks cause this) Or, did you acid wash the entire assembly? - acid isn't good for the fabric of the carts, so should only be done if there is a known calcium issue
    Luv& Luk
