Results 1 to 14 of 14
Thread: can someone tell me how many gallons my pool is?
    shadylady23's Avatar
    Jul 2007
    Western Mass
    71
    I don't remember how to figure it out and cannot find it either.
    I have a 25' round AG - Average water level is about 4 feet.
    Thanks!
    Mary
    18 Round Approximate 8100 gallon AG pool. Intex SF60100 Sand filter. TF-100 test kit.
    I get 14800 gallons. There is a pool volume calculator, and several other handy calculators, in my Pool Calculator. See the link in my signature.
    ktdave's Avatar
    Katy, TX
    888
    Volume = Surface area(ft) x depth(ft)
    = pi x radius squared x depth
    = 3.14 x (12.5x12.5) x 4
    = 1962.5 cubic feet (convert to gallons mult. by 7.5)
    = 14,719 gal
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    using your calculator, using the round which ignores length, I have an 18ft Intex pool round and I have it filled to almost 48in, and it tells me it's 7600 gallons, but on the box it says it's 6280.
    14 x 32 x 6 (ave depth) 20K gallons - IG gunite pool. Challenger 1.5 hp pump and cartridge filter.
    My calculator does a little rounding, but it should always be within 100 gallons. The actual dimensions of the pool might be different from what you think they are or they might be assuming that you don't fill it as full.
    ktdave just gave the equation, except that it is closer to 7.48051945 gallons per cubic foot and I use 3.14159 for pi.
    ktdave's Avatar
    Katy, TX
    888
    I'm a rounder too.
    Pool School
    TF Test Kits
    My calculator does a little rounding, but it should always be within 100 gallons. The actual dimentions of the pool might be different from what you think they are or they might be assuming that you don't fill it as full.
    but, I'm basing my adding chlorine on your calculator and I'm using 6280 as my gallons...when I used your calculator to figure how much CYA to add, from 0, and I wanted to go to 30, it told me 1.75 pounds and it was dead on, using 6280...
    so, that's why I'm confused.
    Jul 2007
    Hillsborough, NC
    525
    Quote Originally Posted by rpgman
    The Intex capacity is not filled to 48". I have an Intex 15' round pool and mine is listed at 4400 gallons but they also say that is filled to some capacity less than 100%. I don't remember what the figure is offhand.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Quote Originally Posted by crokett
    right, so if the box says 6280, but his calculator states 7600, what is correct?
    I think the box is cause I'm using 6280 (which I know I'm not filled to capicity), and I'm adding bleach every night and if I need to bump up the chlorine, it's dead on. If i was using 7600 as my number, my readings would be off.
    The tests are not exact, the volume is not exact, nothing is exact. The CYA test is something like +-15 ppm, so it could really be anywhere from 15 to 45, a much larger range than the uncertanty on the volume.
    Using my pool calculator, moving CYA from 0 to 30 give 1.75 lbs for volumes between 6800 and 7100 gallons.
    Jul 2007
    Hillsborough, NC
    525
    I did some searching. They both are. The difference is Imperial vs US Gallons. This site: http://www.poolandspachemicals.co.uk/volcalc.htm lists the volume of your pool at 6340 Imperial gallons and 7614 U.S and my 15 footer at 4403 and 5287, respectively. The 4403 is close enough to the 4400 Intex says it is and the 2nd number agrees with Jason. This is good to know cause it means I have to revise the amount of water in my pool up some. I only have it partially full and I was basing my figure off of Intex's. I've got closer to 3000 gallons than the 2600 I though. It sucks for all the people who don't know this though and are not using enough chemicals. Maybe Jason can add something for Imperial?
    I didn't think anyone still used Imperial. I am going to work on metric next, but I will add Imperial to the list of things to do eventually.
    Jul 2007
    Hillsborough, NC
    525
    Intex is headquartered internationally, maybe that has something to do with it?
    Jul 2007
    Western Mass
    71
    Thanks guys. again, you are such a big help!
