Thread: High CH - lower now or wait?
    Vero Beach, FL
    462
    My pool is a few months old and the CH has been steadily increasing - probably due to the new plaster - right? Anyway, it seems to have settled at 420. Assuming it will eventually stop curing, what else can make CH rise?
    Using the poolcalculator, my CSI is -.2, so I'm still in the safe zone.
    Should I replace water immediately to lower CH, or can I wait for evaporation and rains to naturally replace it?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: High CH - lower now or wait?
    Fill water is another source of calcium. Also, evaporation and rain will not remove calcium unless it rains so much that you get some overflow. Calcium stays behind when water evaporates.
    As for replacing the water, if it is pretty stable, then I wouldn't mess with it. 420 ppm is not that high. After a season, my CH goes to 600-800 ppm due to high CH fill water.
    It would be a good idea to test your fill water to see if you will be adding any calcium that way. If it is pretty low, they you should be ok for a while.
    Mark
    Vero Beach, FL
    462
    Thanks Mark.
    My fill water is low. Can't remember the number now, but less than 180.
    I knew CH does not evaporate - don't know what I was thinking. I will wait untl a good heavy rain and retest.
    Solar heat
