Thread: Aqua Plus and GVA-24 Help
    I am installing an Aqua Plus system with 4 relays
    1. Filter Pump
    2. Pool Light
    3. Aux1 - Polaris 280 Booster Pump
    4. Aux2 - Landscape & Deck Lighting
    Is it possible to manually control the a Goldline GVA-24 Valve Actuator using this system?
    I would like to use this to turn a water feature on & off.
    Thank for the Help
    Re: Aqua Plus and GVA-24 Help
    Look and see if there is a small toggle switch on the back of the GVA. If there is (I know there is on the Jandy JVA's) you can leave it in the middle (neutral)position, or you should be able to toggle it up or down to reverse the valve. I'm not real up on the GoldLine stuff, so I can't say for sure, but it's worth a look!
    Thanks I will check into the Jandy JVA's
