Results 1 to 8 of 8
Thread: Very cold in Tenn.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Very cold in Tenn.
    It is supppose to get down to 13 in Nashville tomorrow night. So that means probably 10 in my neck of the woods. This is the only night it's suppose to be that cold. Not long term.
    I have a non insulated 9x12 building around all my pool equipment. I've blown out my deck jet lines. My freeze protection is set to kick pump on at 34 degrees. I have the valve to my booster pump open also. This will allow water to flow through it without it actually being on. Will that be o.k. or should I put a heater in my building??? I don't have electricity in it yet, but I could run a 50' extension cord to it if necessary.
    Do I need to put a jug in my skimmer?? If so, do I partially fill it with antifreeze and do I leave the top off the jug??? I've read about people doing this but wasn't really sure how to do it.
    Thanks for any advice.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Very cold in Tenn.
    Quote Originally Posted by orthofish
    The enclosure should help a lot even with temp low for the next few days... I think a space heater set on LOW might be helpful but if the air temperature gauge is in the same building you'll defeat its purpose; so if that's the case, best not to heat the building. Don't know how a jug of antifreeze would work in preventing skimmer from icing over. Maybe other members can respond to this.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    South Central NJ
    3,192
    The jug in the skimmer doesn't prevent skimmer freeze ups. It prevents damage when ice forms and expands. It's contents remains liquid and the bottle remains compressible to provide and absorb expanding ice pressure. On running systems that are not winterized and shut down, use a single quart bottle so you don't restrict the flow and if the skimmer has one, remove the weir (flapper). They can get hung up in ice and block off the incoming water. That would cause you to lose prime at the worst possible time.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    polyvue, I have my temp gauge on the outside, so that it gives my control box the actual temp.
    Thanks PoolGutNJ. That's exactly what I needed to know.
    Thank you both for the response.
    Lynn
    Sanman023's Avatar
    Mar 2009
    Sacramento, CA
    31
    hello polyvue...it was pretty cold last night as well here in sacramento....i believe 24...how do you protect your equipment and do we need to in our area...
    24,000 gallon pebbletec
    Hayward Swimclear cartridge filter C5025
    Hayward Northstar pump 2HP SP1620
    Hayward Navigator
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by Sanman023
    Well, at 11 O'clock I was watching an old movie, trying to hear the sound over the groaning of my 'freeze-protected' pump and got up to do what I had threatened to in an earlier post... viewtopic.php?p=147529#p147529
    Now, don't know that I actually recommend this rash action; if you want to play it safe, run your main pump overnight. So far, however, I've no regrets.
    signed,
    of lower utility bills
    __
    May 2009
    Dallas, TX
    785
    That's exactly what I did with mine as well! The blasted thing just kept running and running, with no chance of really freezing. But I had to shut off the breaker to my pump...couldn't figure out how to override the blasted freeze guard.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I can deactivate my freeze protection if I want to, but I have it set to run my pump on low, so hopefully that's not killing my electricity bill It's been kicking on most every night this past week. Getting pretty cold here in Tenn. when the sun goes down.
    Lynn
