Results 1 to 8 of 8
Thread: Question about Pool Heaters
    HardTrance9's Avatar
    Oct 2009
    Los Cabos
    184
    Anyone has idea on this question maybe?
    http://www.troublefreepool.com/post145805.html#p145805
    Thanks!
    In charge of some SWG and Bleach pools... still a newbie..
    22,548
    Re: Question about Pool Heaters
    Anything, other than solar, that you try and heat a pool with is gonna cost you and arm and a leg. It doesn't matter if it's a heat pump (proper term), electric or gas heater it's still gonna be expensive. While a heat pump is cheaper than an electric heater it's still expensive to heat that much water.
    To me the ideal situation would be to put enough solar in to heat the pool and supplement with a heat pump. That way you only have to run the heat pump on rare occasions when the solar won't quite make it.
    Vero Beach, FL
    462
    Here is central - southern Florida, most people use heat pumps. They are essentially A/C units operating in reverse. They don't work well in cold climates like the norhtern US. They have high initial costs, are large, and will last you about as long as a typical central A/C unit 10-15 years.
    Solar, if done properly (at least in this area) can work in conjunction with a solar cover. I have 50% solar panel coverage facing west and I have lots of shade, so I can't heat my entire pool during the winter. But I only wanted it for heating my hot tub, and I have electric to supplement, and I don't want to bother with a cover. A friend has 100% solar coverage on a south facing roof, a controller, solar cover, etc. He swims year round.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Oct 2009
    Los Cabos
    184
    Great. Thanks for your comments.
    After using those heat pumps mentioned in the post/link above I will share our experience regarding the power consumption and most important the COST...
    Seems like having a supplement is what will work best with solar panels..
    JoshU's Avatar
    New Orleans, LA
    542
    Quote Originally Posted by lborne
    A heat pump is a good option to take the chill off the water towards the start and end of the swim season. In most regions they are not good for deep winter months (i.e. late November - early February, however this certainly varies by area).
    A solar cover is very important to use no matter what type of heater you are using. A solar cover saves money as it stops heat loss. Without the solar cover the top of the pool simply has zero insulation. Some people don't want to mess around with a big solar cover and use a "liquid" solar blanket which is a bit less efficient but much easier and doesn't look bad on top of the pool. There is an option of adding an automatic feeder for the liquid blanket to be added to the pool.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Oct 2009
    Los Cabos
    184
    Quote Originally Posted by JoshU
    Very interesting insights and explanation... thanks as always! Does SaltPool sell this covers?
    JoshU's Avatar
    New Orleans, LA
    542
    We don't sell the traditional solar blanket covers. These can be found at countless online retailers. We do however offer the liquid solar blankets.
    Vero Beach, FL
    462
    JoshU,
    Thanks for the additional comments on my post. You are right, a solar cover can save you tons of money. Most of the people I know who have them don't use them. I know because I've been offered lost of blankets and reels from people who want to get them out of their garage. I find some people keep their heat pump running 24/7 in the winter because they want to swim all the time and justify the cost because their central A/C is off and their electric bills are then more even every month. Other people heat just when they have friends from up north visiting.
    Can you please tell us more about the liquid solar cover? Does it get trapped in the filter? Does it float to the surface? Do you have to keep the skimmer off? How long does it last, etc.
    Geaux Saints
    Solar heat
