Thread: Test FC with Taylor FAS-DPD test
    N.E. South Carolina
    68
    This is my first year using the Taylor kit. It says add 2 dippers of the powder. I'm assuming that, since the dipper is not really a measuring spoon or anything, the point is to add enough powder to turn the sample pink, right? I mean, there's no way to add an exact amount with those flat little dippers!
    Judy
    Designated "pool girl" for 18' x 40' in-ground vinyl pool built in 2006
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yep. Just dump some in.
    New Jersey
    98
    Turn the "dipper" around
    The "dipper" has two ends. One is flat the other has a tiny little scoop. Just add two scoops of that...the flat part is where you hold this "little dipper"...lol.
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
