Thread: Help Deciding - Aquabot Turbo t-2 or Turbo T-Jet
    I decide to purchase a robotic cleaner. I am between the Aquabot Turbo T-2 or the Aquabot T-Jet. The first one runs on tracks with a drive train, while the T-jet has no drive and runs on wheels with jet propulsion. The T-2 looks better and more expensive. Any experiences or suggestions? Thanks.
    Richard, Temecula, CA
    28,000 Gal. In-Ground Black Marble Pebble Tec and tile, Intellichem with Chlorine and PH control, Pentair EasyTouch 8, ScreenLogic Wireless, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, Water feature spillover from SPA.
    Aug 2009
    North Central Texas
    1,358
    Re: Help Deciding - Aquabot Turbo t-2 or Turbo T-Jet
    I may be wrong but isn't the one with tracks used mostly for vinyl pools? I have the iRobot Vero 300 (made by Aquabot) which is essentially equivalent to the Turbo T-jet. The Vero only runs for about 90 minutes and then has to be turned on again to run longer. Hopefully the A. Turbo T-jet has a controllable timer. The really nice thing about the Turbo T-Jet is there are many, many, less parts to break or wear out than many of the other Aquabots or other 'bots. I've been using mine for three years. I've replaced only a small plastic strap that secures the power cord inside (I didn't have to disassemble to replace it) and I've had to readjust the cord some as it was pulling on the remaining plastic retainer. My pool surface is pretty rough so I think I'm going to rough up the wheels a bit as they have smoothed out some.
    You may not have this situation but I have EXTREME amounts of extremely fine sand and silt year round. The fine silt bag fills up too fast, in my situation, so that the bot doesn't make it up the steep slope to shallow end after the fabric gets clogged. There are very few people, though, that will have anywhere near the amount of silt I have.
    Of my three cleaners the "Aquabot" is in the middle when it comes to getting up leaves using the regular mesh bag. The Polaris 280 is the best, with the Tracker 4X (like The Pool Cleaner) the worst but it does the best with fine silt.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    I purchased the T2. I used it twice so far. In one hour it really cleans the pool with lots of leaves. It works great.
