Results 1 to 13 of 13
Thread: Easy Set Pool question
    skydiva44's Avatar
    Houston, Texas
    200
    I didn't close down my pool, just covered it. Houston is predicted to get SNOW on Friday, Crazy I know, but all I plan on doing is to keep my pump running to keep it from freezing up...will that be enough.....any other suggestions?
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Easy Set Pool question
    How much snow are they predicting? If it's just a dusting, I'd think you'd be OK. Anything more than a dusting and I'd start to worry about snow accumulating on the cover, if the cover doesn't lay on the water.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    skydiva44's Avatar
    Houston, Texas
    200
    I'm sure it will just be a dusting, they really haven't said...I can take the cover off if you think that would be a problem, I'm more concerned about the pump, I think I read somewhere on here it was best to leave the pump running when you get into freezing weather...
    5455 gallons
    SWG
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by skydiva44
    Scary, isn't it. I'm just south of Dallas. This isn't going to be a really long freeze, if predictions are correct, so I'm only going to run the main pump while it is below 35. Make sure water goes through the booster pump, if you have one, but you shouldn't have to turn it on. Main thing is to have water flowing through all equipment and pipes.
    When it goes into the mid to low 20s (or teens), for very short periods, I do put heat tape on the pipes and valves and then insulate including the pump pot and valves, making insulation removable from valves so I can operate them. If it's going to be 20's and below for days I drain everything at pump station and add additional insulation. My pump station is below grade so draining is fast and easy to do.
    Up here we have had a few extended days, some winters, where temps didn't leave single digits. On a couple of occasions, in past 23 years, we've even had ice form on the pool. That is extremely rare. I didn't lower the pool water but did put some slightly water filled plastic bottles in the pool and one in skimmer to avoid freeze expansion damage. I don't think lower Texas will be experiencing those conditions any time soon. At least I hope not.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    skydiva44's Avatar
    Houston, Texas
    200
    GG...thank you, I hope you are right! lol Mine is an above ground glorified blow up pool, so I don't have alot invested in it like you do with an in-ground, but I sure don't want it to burst and flood my home...
    5455 gallons
    SWG
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    No, indeed. 5000 gallons of water in the living room takes forever to get up with a shop vac.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Is this the inflatable ring intex or is it the metal pole supports type pool. If it is the inflatable ring pool, I would 1 make sure that the ring stays inflated when the temperature drops, and two if you get too much snow on the cover get it off because the cover generally goes over the ring and suspends above the water. If this happens the ring could collaps inward and allow water out, or even cause it to collapse alltogether.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    skydiva44's Avatar
    Houston, Texas
    200
    It is the ring top type. I have taken the cover off, turned the pump on and insulated the pump and SWG, at this point that's all I can do and pray for the best...we are supposed to have 4 days of freezing temps....of course Mother Nature decides to do this the year I get the pool, it's been 20 years since the weather was like this!
    5455 gallons
    SWG
    Feb 2008
    Northwest Indiana
    900
    that is the way it works...Let me know how it goes...keep an eye on that ring!
    Beave
    skydiva44's Avatar
    Houston, Texas
    200
    I'm happy to say that the blow-up pool made it through the 4 nights of 20 degrees we had here in Houston! DH got me a IROBOT pool vacuum for Christmas....probably can use it this week since it will be in the 70's! WOOHOO!
    5455 gallons
    SWG
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by polyvue
    GG...thank you, I hope you are right! lol Mine is an above ground glorified blow up pool, so I don't have a lot invested in it like you do with an in-ground, but I sure don't want it to burst and flood my home...
    Lucky us. Our house slants down all the way from one end to the other in open living area (lower at the hill drop-off side.) All we have to do is open the back door.
    skydiva, Glad your pool made it. I drained all my equipment, heat tape, and insulation. It was nice not to have to do anything to the pool for a few days. Our ice was at least an inch thick on pool.
    gg=alice
    Jun 2007
    New Jersey
    653
    Northerner here, former EasySet ringtop owner. I can't imagine any problem that icing up would cause to one of those things (talking about just the pool itself), even if it froze solid to the bottom. I just don't think it would expand enough to hurt anything--that vinyl has enough give. Pulling the cover is wise--although snow is no worse than good old rain. It's just harder to siphon.
    The pump is a different story. You can run it 24/7 or just shut it down. Just shut those plunger valves on the pool wall and dump the water out of the little pump. Unscrew the clamps and pull the flex lines that connect to the unit. If you've added a real filter, then pop the plugs and let it drain out. 40°F water can live without a filter for a few weeks--mine sits for 5 months.
    The people that need to worry are those with underground lines and in-ground skimmers that are tough to drain. Whole different kettle of fish.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by Durk
    I would think that because Ice expands upward, that if you didn't drain down the pool a few inches you could do some damage to the top ring if there was too much expansion upward. just my thoughts on the matter
    Beave
