Results 1 to 7 of 7
Thread: Leak at Connection
    Sep 2009
    Houston, TX
    117
    Leak at Connection
    I'm having a hard time with a small leak. It's occuring at the connection point for my booster pump. My pool guy (yes I have one) tried to correct the issue using some sort of pipe dope but it doesn't seem to be working. Said the leak was fine and not something to worry about but me being the perfectionist want it fixed. Any thoughts on what may seal this better? Picture for reference
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
    22,551
    Re: Leak at Connection
    That hose being kinked may be causing the pump to put more pressure on the fitting than normal. (I haven't liked that kink since you first posted that pic) Still, it shouldn't leak.
    If it's leaking at the threads, remove the fitting and take a small wire brush and clean the internal and external threads real well then apply several layers of teflon tape and reinstall it. Be sure to inspect the pipe fitting and the pump discharge fitting closely for cracks while you have it apart.
    If it's the joint where the pipe slips onto the fitting then remove the nut and the pipe. Trim an inch or two off the pipe and reinstall it onto the barb then reinstall the retaining nut. Don't overtighten the retaining nut.
    P.S. If you were as much a perfectionist as I, that tubing being kinked would bother you way more than a lil ole water leak.
    Sep 2009
    Houston, TX
    117
    Thanks Bama. And I'll look in to fixing that kink, may have to get something around that area to keep it rigid.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    That plumbing job is hilarious. I like that someone installed a 45 on the line so it would connect up with that big floppy piece of flex at just the right angle.
    The reason that kink is there is because of the full-weight and height of the 3/4" line. There's too much torque on the plumbing. I'd trim more like a foot or two off so that the line is pretty much a direct shot. Some slack is good but it looks like you've got about twice as much as you need there.
    Aug 2009
    North Central Texas
    1,358
    That hose, also, looks to be a more flexible hose than I've had on my booster pump and those I've seen of friends. The ones I see are a semi clear reinforced hoses that are really stiff. I was going to recommend putting support cuffs on each end of the hose, for some support, similar to the ones you see on garden hoses. But if the hose was more like the ones I usually see that wouldn't be necessary.
    I use small submersible pumps (one died so getting another) for pool and spa and other uses. I keep the hoses attached to them for quick use in emergencies. Just about any garden hose I have ever used with them kinks like that near the connection point, during storage, (even using the collars - they just kink above the collar), especially if I set the pump upright, rather than on its side. If the sun heats them up, over a short period of time, the hoses will form a permanent kink.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    May 2009
    Dallas, TX
    784
    Quote Originally Posted by geekgranny
    That's exactly what I was thinking. I recently replaced one of those hoses on my booster pump, and the replacement was the same type as the original: A very stiff black reinforced hose that I don't think is even capable of kinking. Bought it at Leslie's. Also, as mentioned above, the hose in the pic is honking long! I don't see why it should be more than 1-1.5' long.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Sep 2009
    Houston, TX
    117
    Maybe I'll just replace the hose then. I had the pump replaced early on in ownership and that's the hose he used to insall it. Got me wondering about his knowledge now.
