Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: Building Chlorine Injector
    Jun 2007
    Charleston, SC
    151
    Wasnt sure what section to post this in.
    I am starting to think about designing a cheap way to constantly add bleach to my pool.
    I have seen people using that liquidator, and also the pump systems.
    All I am interested in really building is a system that will open a valve at certain intervals for a set amount of time, and I will adjust the timings if my chlorine trends upward or downware.
    Knowing the flow rate of my system would also give me the ability to put a "+1 ppm" pushbutton on it that i press and it opens the valve for the right amount of time to let enough bleach to flow to raise my ppm up by 1, so if i test, or if i want to shock, I just go push the button the appropriate amount of times.
    I have the solenoid valves, the tubing, and the electronics to throw this all together, what I am interested in is some suggestions for tank, or any features that might be nice for something small like this.
    I was thinking of just getting a 5 gallon container (like one of those water cooler jugs), putting it in a wooden box near the pool (built up to look like a patio table or even a planter with a plant on top) and then running it that way.
    I was also looking for suggestions on how you think I could run the line to the pool to get the bleach in it. I was thinking of maybe drilling a small hole in the return pipe and putting a fitting or something in there to attach the tube from the bleach dispensor.
    Thanks for any thoughts/suggestions!
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Without a peristaltic pump it is difficult to get consistent flow rates from the bleach reservoir into the pool. The pressure on both the suction side and pressure sides of the system will vary depending on the state of the filter so flow rates will tend to vary. There are a few companies that make special contant flow rate despite varrying pressure valves but they aren't common. A peristaltic pump with a suitable storage tank can be gotten for around $400-500, made by companies like Stenner. That isn't exactly the true DIY approach but they are very reliable and consistent.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Injecting into the return line will require a pump. Otherwise you'd fill your chlorine container with pool water. The easiest way is to use the pressure difference across the filter like the Liquidator does to inject chlorine on the suction side. You'd also have to keep the tank cool some way to avoid large losses in strength. The Liquidator seems to have solved most of the issues.
    You might be able to run a line into the skimmer and gravity feed into there.
    Why couldn't one use venturi suction with some sort of valving to control the outflow?
    Similar to a pressure washer. Most have a plastic hose for injecting soap, etc into the spray.
    Only for a pool you tap into a return pipe, run the hose from the line to a container and regulate the diameter of the hose via valving or similar to control bleach input?
    Jun 2007
    Charleston, SC
    151
    Thats exactly what I am going for. I would probably have to add a venturi injector in parallel with my return or something, but this is where I was headed. Either that or gravity fed. With gravity feed, the flow rate would depend on how full the container was, so thats something to take into account.
    I wouldnt think that having this stored in a box under the deck would be any hotter than my shed or my garage where I keep my bleach now.
    This stuff has been worked on for years in the landscaping industry. The problem is always how to inject fertilizer or other chemicals into the irrigation system.
    If I see the liquidator right, it is a modified pressurized mixing tank, with the lower port moved up to the top so it doesnt mix the tank like a fertilizer tank would be mixed up.
    http://edis.ifas.ufl.edu/EDISImagePa...04F11&credits=
    TEXAS
    34
    I have all my stuff ready to go to install my chlorine injection system using a peristaltic pump.
    You can read the details here .
    I thought of other ways similar to what you are suggesting but I think what I am doing is easier, cheaper, and replaces the chlorine as it burns off so the level remains constant instead of having it bounce up and down by adding a dose after it has burned off.
    In the post I linked to, I said I was ready to install it, but the install got delayed due to a death in the family and now I am swamped at work. I should have a chance to work on it again in a couple weeks.
    I've got everything ready to go and have spent under $50. This includes the tap I had to buy and a role of Teflon tape.
    Jun 2007
    Charleston, SC
    151
    Yeah, I also have decided to go the peristaltic pump route.
    Gives me the ability to have the tank lower than the pool water line, under the deck where I can keep it cool and out of the sunshine.
    Im just adding the circuitry for a small control panel, and a ppm per day display that will pump in the correct amount over the course of a day.
    Mar 2007
    Virginia Beach
    272
    I don't know why you wouldn't just buy a Liquidator, it has so many benefits IMO. I've had mine for about two months:
    A. It's only $133.00.
    B. A snap to change settings.
    C. The cold pool water layer keeps the temps low so the bleach stays strong.
    D. Adds a layer of water over the bleach to minimize fumes.
    F. Takes no electricity.
    G. Very easy to install and configure.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Jun 2007
    Charleston, SC
    151
    For some reason, I am still extremely skeptical of the liquidator. I cant really explain why.
    Tell me more about it, and your experience with it.
    Ive read the other threads, but still want more info. The info coming up in google is pretty lacking.
    Do you have to add bleach outside of what the liquidator adds (other than shocking of course)?
    How often are you finding you have to fill the liquidator up?
    Do you find that it actually holds the chlorine level where you want it?
    Quote Originally Posted by keithw
    Actually, because it uses a pressure side to suction side bypass it reduces the efficiency of the pump ever so slightly, so it probably takes about as much electricity as a peristaltic pump would. In neither case is the electrical usage significant, so this isn't really a point in favor or against either approach.
    It does look like a nice unit and the extensive discussion over on The Pool Forum is quite positive.
    Mar 2007
    Virginia Beach
    272
    To answer Wolfmarsh. Yes there is scant information on it. I was hesitant as well but decided it was worth the chance for $133.00. Since installing a little over a month ago, I have added no bleach outside of what I put into the Liquidator nor have I had to shock at all. I have been perfectly clear and have had a near perfect CL level continuously.
    To Jasonlion: Yes I am sure that it probably does somewhat reduce the efficiency of the pump, but I would guess that is it very slight and for me was unnoticeable. My point with the peristaltic pump is that it is one more electrical device that can have a problem. Not to mention the fact that the decent ones are very pricey.
    Liquidator
    keith, do you run your pump continously? On low speed by chance?
    Mar 2007
    Virginia Beach
    272
    No I run mine for a total of six hours per day in three separate sets of two hours each in morning, afternoon and night.
    Liquidator
    How many turnovers does that amount to daily?
    Thanks.
    Mar 2007
    Virginia Beach
    272
    Ha! I have no clue. I have a 6600gal fiberglass pool. I think around a 1HP pump.
    Liquidator
    Jun 2007
    SF Bay Area
    441
    I do not have any experience with The Liquidator, and the information on their website is fairly scant.
    However, The Liquidator is evidently manufactured by (or for?) HASA Inc. After a little research, HASA appears to be a fairly large supplier of pool and industrial chemicals. If anyone knows how to best apply sodiium hypochlorite to a pool, I would imagine it would be HASA.
    Comments welcome....
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    I've had my liquidator for about 10 weels or so and have been very happy with it. It is important however to watch the pH and alkalinity. If the pH gets too high you'll get deposits and it will gum up the unit. It's super easy to clean though.
    My feeling on this whole thing is why reinvent the wheel? The Liquidator is not a perfect solution but one that is well executed and very simple in operation. By the time you factor in all the parts, time and effort involved you'll surely have more invested than $135. Having said that maybe you like to tinker and think of it as a challenge regardless of cost, in which case enjoy yourself
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jun 2007
    Charleston, SC
    151
    Yeah, i do like to tinker .
    I have everything I need other than the peristaltic pump, which it appears as though I can score on ebay pretty cheaply.
  20. Back To Top    #20
    TEXAS
    34
    Quote Originally Posted by cruzmisl
    Like I said, I've spent about $50 which includes buying a tool which I can use for other projects.
    The Liquidator can't be controlled by a home automation system........ well, maybe it could.
    Yes I like to tinker, but I don't think there is any more tinkering with a pump than the liquidator requires.
    Why reinvent the wheel? I don't think using a mechanical pump is reinventing the wheel. It is the more common way of doing things such as this. I'll still throw out my usual response to "why reinvent the wheel" .... ask Robert Thomson.
