Thread: The more I read...the more I get....
    ..confused!
    Background
    roughly 20 year old, 12K gal, in ground.
    Hayward cart filter 120 sq.ft.
    Dead pump is a Hayward 1 1/2HP motor, yes, way oversized! ( pool orginally had an attached spa....no longer operational, thanks to orginal owners stupidity...same owner that stopped up bother drains.
    So, that leaves me with a single 1.5" pvc to feed the pump, with 2 1.5" returns.
    From what I can determine is my piping will handle a maximum flow of 42 GPM. Determining the head is where I am getting confused. From skimmer to pump is approximately 15 ft, with 4 90 elbows and 2 45 elbows. In reading a few websites is seems 50 ft of head is average. Should I use that figure?
    With the 1 1/2 hp pump my gauge(clean filter) was roughly 11psi....was that about 30 ft of head? (11*2.31+5)
    Any suggestions for a complete replacement pump?
    Thanks in Advance
    Happy Thanksgiving!
    Jul 2009
    Monterrey, MX
    37
    Re: The more I read...the more I get....
    If you have an equivalent leng of pipe of 50 ft in tha suction side of the pump and a flow of 42 gpm, with 1-1/2" pipe then the head loss in the suction side is 4.6 ft.
    You add the equivalent leng of pipe of each elbow and the pipe, then find in table for 1-1/2" pipe (wich shows head loss for each 100 ft of pipe lenght) the head loss for a given flow and calculate for the lenght you have. In your case is 9.2 ft head loss/100 ft pipe for 42 gpm.
    Then you add the output head loss.
    Gumaro
    10' x 20' x 52" In Ground Pool 6,600 gallons, 2" piping, TFTestkit
    24" Sand filter / Espa Silen 0.8 hp pump
    30,426
    fsully,
    I can tell you from several years on these forums that a .75HP pump will do fine. Others are much better at the math if you need to be more precise but I think your answer will still come up 3/4HP.
    Would there be any problems using a 2-speed 1 HP? I found a Hayward SP2607x102S with the switch, that will be a close match to my current set up. Also found a Pentair 340042 Superflo that would work also. Any pros/cons with either of these pumps?
    Any why doesn't Hayward list any electrical specs? Almost every unit I looked at I could find an AMP rating, except Hayward products. But then again I couldn't find dimension on the Pentair products.
    30,426
    That makes great sense to me. Probably run it on low 12+hours a day or so and then use the hi-speed for vacuuming, etc. You'll save a lot of money on your electric bill.
