Thread: Leaking at skimmer...
    I had someone (Leak ID company) contact me about a leak at their customer's skimmer - It is leaking between the tile and the skimmer. There appears to be no grout.
    Is this an easy fix?
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Re: Leaking at skimmer...
    It should be an easy fix. I found out that I was losing too much water and the PB came back and found that they did not grout the tile at the skimmer basket. They just put grout there and my pool has not lost water since they did that which was about 2 weeks ago.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    just regular grout you get at HD?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    I know that they used regular grout for my tile work because DW wanted a different color than the standard white so she picked up regular grout from HD. To be honest with you I do not know if there is a special grout used for pools.
    Hopefully someone with more knowledge will come by and give us answers
