Thread: Calcium Question
    Calcium Question
    A newbie second season with refurbished concrete plaster/painted pool 48,000 litres.
    Have good clear water with test (Bioguard) as follows
    TDS 500
    stabiliser 40
    Total chlorine 4
    free chlorine 4
    TA 90
    calcium 88
    ph 7.5
    pool shop says I need 7.3 kgs of "Bioguard Balance pak 300" they are Bioguard outlet of course. as I have supported their lifestyles to the tune of about $300 to get the pool going this season I want to use this forum to keep costs reasonable!
    With no metal fittings except the odd bit of stainless steel what should I add if anything. I need to find a test kit that does the business. Cannot source trhe ones listed on the forum out here in NZ but plenty of others when I get to the bottom of what is ideal.
    Raynor J
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Calcium Question
    Check out the article in Pool School about recommended levels pool-school/recommended_levels then the one on recommended chemicals pool-school/recommended_pool_chemicals
    Thank you shall do.
    Raynor J
