Thread: FNS Filter use with Salt Water Pool
    Phillbo's Avatar
    Oct 2007
    Scottsdale, AZ
    81
    Hello, my FNS Plus DE filter was leaking a bit at the bottom drain this morning so while I was tightening the plug I noticed the label states "Suitable for Fresh Water Use Only"
    Has anyone experienced issues with using this model with a Salt Water pool ?
    20000 Gallon In Ground Plaster , SGS Breeze 540 SWCG , 1 HP WhisperFlow Pump , Pentair FNS Plus 48 DE Filter , Hayward Navigator Cleaner , PS234 Test Kit (old school)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: FNS Filter use with Salt Water Pool
    I expect they just don't want you using it for sea water at 35,000 ppm. 3500ppm salinity pool water is fresh water compared to that.
    South Central NJ
    3,192
    That is exactly correct.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
