Thread: Need some advice on water issue
    May 2009
    Raleigh,North Carolina
    21
    My PB seems to have disappeared so it looks like I will have to pick up where he left off. I have been pumping water out of the dirt pool hole every day. Everything is done for the pool except for the vermiculite and liner. The concrete decking has been poured and the edges are smooth. However I have to figure out how to deal with the water issue before I can put down the vermiculite. If you have any suggestions I am all ears. Quite frankly I don't know how much more the north carolina red clay walls can with stand since the hole was opened on September 2....
    Freeform 18' X 36: 20,100 Gallons: 2" piping, 1HP Pentair Whisperflo, Pentair Triton II Tr-60 filter,Pentair IC-40 Chlorine generator, dual main drains,3 returns,
    30,432
    Re: Need some advice on water issue
    Just keep pumping. It's virtually always repairable when they do the vermiculite but keeping as much water out as possible is helpful....mostly to your PB since he'll have to do the patch work.
