Thread: Pillow moved to side of pool under wintercover
    West Michigan
    108
    The pillow in the center of my 28ft agp has moved to one side of the pool. We have a solid winter cover in place witha plastic covered wire rope/toggle system, with extra plastic clip things on the wind exposed sides. Is there something I need to do about this or just wait untill spring? We live in West Michigan and while its very cold here, no snow yet. First year with big pool.. Thanks, Kim
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pillow moved to side of pool under wintercover
    That happened to us the first year we had the pool, then we learned to tie it off on at least three sides - if it's not tied there may not be much you can do - but maybe try and push it back with a broom or something soft? It probably won't make much difference, didn't hurt our pool any.
    Good luck...
