laurandavid09 said:
From December 19th-January 2nd I will be out of town. I will not have anyone to care for my pool at that time. What are some things I need to do to keep my pool from getting out of control? I know it is early, but want to be prepared.
Thanks.
I forget. Do you have a cover? If not, how much debris to you think is going to get blown in?
Twice, I've had to leave country late Dec, with only a couple of days notice, for a month, each time. I do not have a cover. Two people were here but they would not take care of the pool, properly. I had to just shut the pool down, drain pipes and equipment at pad and put heat tape on exposed, water filled pipes, and then some insulation (my pump pad is below grade so no way to get all water out of exposed pipes and valves on short notice) When I returned it was a real mess. I didn't tackle it until March when the weather warmed up so it went from green water (with black bottom from decaying leaves and silt), to light brown, to dark brown, then to almost black. If I had known what I know now (thank you TFP) I could have kept it somewhat in check, when I returned, and until March, by using a small, inexpensive submersible pump to keep water circulating and lots of chlorine. The debris would still have kept entering the pool but at least the water would have been kept lighter (safety issue and staining issue) and the organic staining from the debris would have been kept to just the bottom and up only a foot on the walls. Major shocking, when the debris is clean out, usually takes care of most of the organic staining.
In my situation, and possibly yours too, if you don't have a cover, the main danger to the equipment is the main drain, pump pot, and skimmer clogging up so that not enough water gets to the pump. This is usually a "death sentence" for a pump.
Good that you have time to get some input from members. Stay tuned and members will ask questions and give great advice. :-D
gg=alice
