Thread: adjust pH to achieve best CSI as temp drops?
    tedinelkgrove's Avatar
    Jul 2009
    Elk Grove, CA
    Pool calculator gives me a better CSI w/ a higher pH at lower temps. Should I keep pH at 7.8-8.0 if that is optimal based on my current water chemistry:
    CSI, 0.02
    Water Temp 55F
    pH 7.9
    TA 70
    CH 310
    CYA 45
    CSI is -.27 with pH 7.6 and all else remaining the same. First winter as a pool owner and just want to make sure I don't let anything get out of whack.
    ~15000 gallon inground, plaster pool
    Jandy CL460 Cartridge Filter Tank, Jandy Stealth SHPF 1.5hp pump, Pentair Legend II cleaner
    Leslie's DPD Complete Test Kit, TF Tests FAS-DPD Chlorine Test Kit
    Heliocol solar pool heating (HC-40 x6)
    Mar 2007
    San Rafael, CA USA
    Re: adjust pH to achieve best CSI as temp drops?
    The pH normally rises on its own as the water temp drops and that tends to keep the CSI fairly constant. If for some reason this didn't happen with your pool, then yes you could raise the pH somewhat. It's not that big a deal, especially since the water temp is cold so everything slows down.
