Results 1 to 15 of 15
Thread: High FC Level in SWG Pool
    Apr 2009
    Orange Park, FL
    104
    Current reading:
    FC = 15
    PH = 7.5
    Alk = 80
    Salt = 3300
    CYA = 70
    My FC level has been high since mid October and after adjusting the SWG output knob down several times, I finally turned the switch off. The switch has been off for a week now and the FC reading hasn't changed. I'm using the Taylor kit and my reagents are fresh. The weather is cooler so I know the FC level is not decreasing as much as during the summer heat. However, I would think it should have decreased some in a week. I live in North Florida and while the unit has been off we've experienced a few cloudy and cooler days and nights. My pool is also in a screen enclosure. During the summer, my pump runs 12 hours a day. I've since scaled back to 6 hours/day.
    I'm perplexed and have many questions......
    Is the SWG is working correctly? Everything seems fine as there are no flashing lights, etc. Could there be a problem with the adjustment knob and it was "overproducing"?
    Is it normal that my FC level is not decreasing with the SWG off? Also, can I unplug the power cord to the SWG power box while the unit remains off?
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: High FC Level in SWG Pool
    If the conditions are right, it would certainly be possible for the FC to remain stable - if there were no organics or sunlight to consume the chlorine...I've experienced that in my own pool. If no one has been swimming, if the pool doesn't get direct sunlight... Does your screen enclosure have a roof?
    Apr 2009
    Orange Park, FL
    104
    Quote Originally Posted by frustratedpoolmom
    The enclosure is all screen, including the roof. I don't have a heater so we stopped swimming a month ago. I'm sure you are correct that with the cooler weather and a few cloudy days the chlorine is not being consummed as quickly. I'll check the FC level every couple of days and will restart the SWG when warranted.
    Jul 2007
    Brisbane, Australia
    874
    what's your water temperature currently? there is a minimum temperature, below which chlorine is virtually not used up
    Apr 2009
    Orange Park, FL
    104
    Temp is 66 degrees during the day.
    Jan 2009
    Cupertino, CA
    1,966
    Cold water and the sun being low will really reduce chlorine use. I'm not doing as well as you are, losing around 2.5ppm per week. But your CYA is twice what I have, so I'd expect you to lose less.
    --paulr
    BBB "Intermediate Swimmer"
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by jagfan
    yeah, a lot of SWGs actually turn of around 50-55 so you are very close to it
    I'd say you can safely turn it down to minimum, or even completely, and just monitor your chlorine level.
    Vero Beach, FL
    462
    Your SWG is probably operating normally. I'm in Mid - Southern Florida, with a screen enclosure, 76 degree temp, but my FC level has been above 10 for a month now. I've had my SWG on the lowest setting (10%) for 3 weeks and off this past week and still it is still above 10.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Aug 2009
    North Central Texas
    1,358
    I'm in Dallas area. Water fell below 60 F past few days. Much more chlorine use above 65 F. Some days are in high 70's; nights 40s-50s. Chlorine use has dropped drastically even with leaves and dust blowing in. Leaves and dust sit in pool overnight till I run pump during day and still isn't consuming chlorine as much as I thought it would. Doggies aren't getting in pool nearly as much either. We had a few inches of rain the other day and it took it down less than I figured it would, too. Sun only hitting 1/3 of pool for about 3 hrs a day now, and with about 1/3 of days being overcast. I've been raising my CYA, by hanging CYA filled stocking into pool. In summer it dissolved in about 24 hours. It has taken almost 2 weeks for it to dissolve now. I did an AA treatment a few weeks ago. With water temps in 60's the process took almost two weeks vs a couple of days when temps are near swimming temps.
    As far as I can see everything is really slowing down, just as our experts advised. It's really nice not to have to take readings so much. My CYA read 30 the other day but I'm expecting it to increase a bit more since everything has slowed down so much.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Nov 2009
    Katy, TX
    94
    I also have a SWCG and lately have had to turn the dial down to 20% from 35% (running 4 hours of pump time daily). Latest test results from the shop were; CYA 38, TC 6.5,FC 6.5, PH 7.4,Adjusted total alk. 88, CH 309, Salt 3400 average water temp 63-65ยบ..I gues with low temps an 0 bather load...Chlorine is abundant...
    Inground with 7x7 spa (spillover)
    20k gal plaster (sunstone)
    pentair 3/4 hp (filter), 1 hp (spa), 1/2 hp (features)
    cartridge filter
    SWCG IC-40
    Polaris Platinum (with booster)
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,078
    jagfan, I think this is normal. My FC has been 14 for the last month and I have my pool pump running for 2 hrs and the SWG is at 5%. We also have an enclosure and the water has been crystal clear. I still have to add a cup of muratic acid weekly as the pool is only 3-4mths old and we have a lot of aereation due to the water features.
    Last weeks tests
    FC 14.5
    CC 0
    TC 14.5
    PH 7.5
    T/A 100
    CH 375
    Temp 75
    SWG 3000
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Apr 2009
    Orange Park, FL
    104
    Brentr
    My SWG is still off and today the FC is 10, so it's coming down. I've got the pump running 5 hours each day and like yours, the water is crystal clear. I think I'll try running the pump about 3 hours and see how it goes. This is my first fall/winter with the SWG and screen enclosure. I'm just amazed at how neat and clean everything looks and with so little effort. The enclosure is the best money I've ever spent on the pool.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,078
    Yes, pool screen enclosures are the best. They keep out all the leaves and grass and crawling critters Honestly we could not enjoy it especially at night when all the nats and mosqitos come out. Take a look at our Spool Build in the siganture bar
    Apr 2009
    Orange Park, FL
    104
    Brentr
    Enjoyed the pics. Your pool is gorgeous! I love the pavers and extending them into the Florida room was a perfect touch.
    Nov 2009
    Katy, TX
    94
    Just to follow up, last Saturday pool store reading for FC went up from 6.5 to 8.5 even though I had set me pump time to 3 hrs (from 4) and SWCG output to 20% (from 30%)....Today I just set the Intellichlor to 0% and hope to get FC down to 2-4 range...water temp 59-63 in the last 8 days....expecting lower temps this week
    cartridge filter
    SWCG IC-40
