Thread: How long should it take to fill the pool?
    joeg2246's Avatar
    Sep 2009
    Cocoa, Florida
    63
    My pool has bee filling for almost 40 hours so far and it is still 6 inches from the returns. The pool is approximately 18ft x 32ft and the deep end is 5ft 3in. I am using 2 garden hoses for the fill. I was told originally about 24 hours, but, am wondering if there might be something wrong. Can anyone give me some insight on this?
    Joe
    25x15 pool & 5x7 spa, Pentair Easy Touch 8, Pentair Intelliflo, Pentair Ultratemp heater, Pentair C&C 520sqft, Pentair Screen Logic 2, Intellibrite 5G pool & spa lights
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: How long should it take to fill the pool?
    Does it appear your pool has filled to a certain point and will not go higher, or has it taken 40 hours to get as high as it is and the water level is still rising? If you suspect a leak, then walk the property around your pool and check for soggy ground. Also make sure a waste valve is not open, especially if it is connected to the sewer system.
    Love TFP? Become a
    TFP Supporter!
    joeg2246's Avatar
    Sep 2009
    Cocoa, Florida
    63
    It appears as though the pebbletec installers did not plug the proper fittings in my main drain. I am using a 32 inch main drain that has 3 2" fittings on it. Only one is used for the main drain and the other 2 have to be plugged. Plumber is on his way to fix it right now.
    Sep 2009
    Spring, TX
    258
    Any update?
    joeg2246's Avatar
    Sep 2009
    Cocoa, Florida
    63
    It was as suspected. The plugs in the main drain were in the wrong location. Got them configured correctly and it is now full and not leaking. Thanks
