Results 1 to 9 of 9
Thread: SAND in the POOL or Calcium deposits
    mred's Avatar
    Sep 2008
    everywhere
    29
    i have noticed here lately that my pools has what appears to be sand. someone suggested "pool store" that is probably "DE" but the "DE" is 1000Xs times finer than what i am getting out of my pool.
    im getting what looks to be SAND or is it Calcium?
    i use a fine leaf bag to peak up the leaves.
    the bag is also picking up this "sand" which is real small balls that look like "sand".
    can anyone help or give a clue.
    thanks
    Ed
    "Dry Gun" inground, Hayward 6020 D.E.,1/5HP
    30,000
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: SAND in the POOL or Calcium deposits
    If it looks like sand and is shaped like sand then.... it may be sand! You have a sand filter --perhaps that's the source. Other possiblities: sand/dirt blown in on the winds; undissolved granules from some dry chemical added to your pool; large pollen or some other plant-like debris from nearby trees; precipitated solids (calcium, metals etc.) from very high or very low pH.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    mred's Avatar
    Sep 2008
    everywhere
    29
    its pool plaster.
    did some talking with a pool guy.
    he asked me questions, we talked, and checked my chemicals.
    bottom line is readings are good and i neglected to vacuum the pool in quite sometime.
    30,000
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by mred
    its pool plaster.
    Hmmm... the pool guy said this was pool plaster? I recall that I had some plaster dust during the first couple of weeks in my newly plastered pool, but nothing ever again like that. If this is still a concern, I would recommend performing/documenting a full set of test results (pH, FC, CC, TA, CH & CYA) and then performing an overnight chlorine loss test, explained here: pool-school/overnight_fc_test
    If you don't have a test kit that will enable you to conduct these tests, now is the time to get one!
    __
    Mar 2009
    Auckland - New Zealand
    48
    i would doubt if it was plaster. Is it the same colour as your pool surface ?
    lack of vacuuming generally doesnt cause the plaster to fall off
    May 2009
    Dallas, TX
    782
    thanks
    Ed
    I get this too, and just assumed it was DE. Never worried me too much...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    X-PertPool's Avatar
    Exeter, PA
    1,385
    sand is usually brown, and doesn't cloud when brushing it just kinda moves and falls right back down.. no "poofing"
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    30,403
    It is not calcium. Calcium precipitates onto surfaces.
    PS - your geographic location is important should you have a question that is influenced by climate. (like closing or summer temps, etc.
    mred's Avatar
    Sep 2008
    everywhere
    29
    im in Dallas,Tx
    i hadnt vacuumed my pool in a long while. due to the fact i was out of town alot and i just didnt want to mess with vacuuming when i was here,did just the basics.
    i know,im lazy
    30,000
