Results 1 to 7 of 7
Thread: Tropical storms & excess pool water
    Jun 2007
    North Florida
    79
    We've pretty much finished weathering Tropical Storm Ida and are none the worse for wear, thankfully! But the torrential rains made me wonder what to do with the pool in the event of an evacuation needed for a bigger storm. You know....when we're not at home to get the excess water out of the pool. The way it has rained here ever since we moved here also makes me wonder how people can go on vacation without worrying about their pools overflowing while they're gone!
    Our pool is in a screened enclosure with paver deck between the pool and house. While there ARE some long, skinny deck drains, they're not extensive and I'm not convinced they'd handle an overflow situation without a problem. I'm also not sure the pavers are set to direct ALL the water toward those drains and away from the house.
    When we moved in, there was no way to drain off excess pool water other than opening up the filter plug at the equipment pad. So, at this forum's advice, we had a hose bib inserted into our pool plumbing, so at least we can run a long hose and drain water that way. But, someone still needs to be here to turn the faucet on and off, or nothing gets drained.
    Certainly, we can't be the only ones in Florida with concerns about overflow in an enclosure. What does everyone else do?
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Tropical storms & excess pool water
    You can essentially pretend like the pool doesn't exist in that situation. The water you'd see if the pool overflowed is exactly the same as what you'd get if the area was paved or a concrete slab. The only water that will come out of the pool is rain that lands on the pool surface after the pool is full.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    I had the same concern when we had our pool built however Johnt hit the nail on the head. When the pool overflows the water will just flow over the pavers and eventually some will flow into the drains and some off the pavers. This would be a good time to backwash to drain the pool and also in turn clean your filter. Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jun 2007
    North Florida
    79
    Thanks guys! JohnT, your explanation makes perfect sense - I feel like a bit of an idiot for being concerned!
    Brentr...your idea to clean the filter to get rid of some excess water makes sense, as well. Now I wish I had that big monstrosity of a Sta-Rite System 3, 2-cartridge filter that I had on a previous pool - that filter had a huge capacity and could REALLY use a lot of pool water when it refilled after a cleaning!
    Sandy
    Jan 2009
    NC
    49
    thanks for sending her my way, when Im supposed to close my pool this weekend.
    John
    15x30 inground vinyl pool. 1 hp hayward pump, 200 pound sand filter. 8 feet deep in the deepest part. 3 feet in the shallow. 4 returns 2 in the steps, 1 in the shallow end, and one in the deep, 1 skimmer (wish there were 2) and one Main drain. Only thing I wish is I had a more powerful pump, The jets never really put out alot of power. No frills pool. Has a light and thats about it as far as specail features go. BBB user ever since I opened this season thanks to TPF
    Jun 2007
    North Florida
    79
    Quote Originally Posted by gman
    Yeah, the mid-Atlantic and East Coast states really got hammered a whole lot more than us.
    Sandy
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    We did not get much here in Jacksonville. Wish we did because we are under a water restriction. In fact the whole state of Florida is under water restriction and can only water once a week
