Results 1 to 13 of 13
Thread: Salinity (and NOTHING else!)
    OK. I am the guy with the mucky pool.
    I have confirmed the fact that the 7800 ppm TDS is salt, using a NaCl-only test strip. I know they are RnR but it's close to my TDS meter reading and so way out of the ball park that it does not matter.
    The PH is 7.4 Yay!
    But that is jumping about. It was 6.5 a couple of days back. But according to my test kit, the TA is HIGH ????
    - however I have dumped a heap (10,000 litres?) of scheme water in there, and that is slightly alkaline.
    Everything else is sick.
    CYA = 0
    TA = 200
    PH = 7.4-7.5
    Free Cl = 0
    Total Cl= 0
    - I bought some liquid chlorine only yesterday, to use until my chlorinator arrives
    Total Hardness = 800
    - I am assuming that this is because the calcium hypochlorite has been used excessively (dozens of 10Kg packs around the place empty.) Just constant powdered chlorine. No filtering, no backwashing. Dump in tonnes of salt, and you have a "salt water pool"
    Now I am assuming (sadly) that the only way to get rid of the salt and Calcium is to dump half the water?
    Can I live with the salt and use something else to kill the hardness? I would allow the salt to fall by backwash and *I assume that the chlorinator will also gradually use it up when it makes chlorine that then goes away.
    Desperately yours. Help appreciated.
    Nick
    Perth Western Australia
    ~20,000 US liquid Gal (~80000 L) inground concrete, pretty much oblong roughly 11m * 8m and 1.2 - 1.8+ m deep SWCG, 24" Sand filter, Hurlcon 1hp pump
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Salinity (and NOTHING else!)
    Quote Originally Posted by OldNick
    What kind of chlorinator are you planning to install? Some SWGs don't have an upper level on the amount of salt in the pool. But since your Calcium Hardness is also approximately double the concentration necessary, doing a 60-70% drain and refill is probably the best choice. You mentioned "scheme water" and this is a new term for me. Be sure whatever you use for make-up (fill) water is reasonably low in CH.
    A SWCG won't use up the salt. Only backwashing, overflow, spash-out and draining/refilling will reduce the salt and calcium levels.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Thanks for the reply.
    I am awaiting delivery of a SWG. There is one there now but it's a joke for the size of the pool, from all I have read and been told. It is also in pretty bad shape and very old.
    So no chemical to lower CH?
    Scheme water = tap water, from the town mains. I will do a hardness test on it
    If that's no good I will just have to drain and wait for next winter, arranging a huge catchment from roofs and things.
    Come to think of it, dumping 50 Kl of water goes against my feelings so much I may just do that anyway. We are on watering restrictions: twice a week only and just yet moving into Summer.
    Nick
    polyvue's Avatar
    Aug 2009
    1,215
    I'm not a chemist, but no chemical or process other than draining that I'm familiar with will deplete calcium.
    Perhaps you could perform partial drain/refills?
    __
    HAH! I have already been doing that, trying to get rid of the suspended calcium.
    A lot of it is suspended calcium, but I have learned that the beginnings of algae can cause cloudiness as well. It's really difficult to tell, because the water was clear, but with huge deposits of stuff on the walls and bottom. Not scale so much as just stuck dust. I clouded it all up again by stirring the water, then keep filtering. But I am only getting an hour out of the filter before it goes into the red and I have to backwash.
    The stuff that was there before settled pretty quick, so it may be algae. I am going to shock with liquid chlorine and see what happens.
    I guess the thing to do is drain half, then just treat that, saving chemicals. Whether I refill or not is in the lap of the gods right now. Toss a coin.
    Nick
    Jan 2009
    Cupertino, CA
    1,966
    I can't remember if you tried this before, but if the stuff settles on the bottom reasonably well, you could try (slowly) vaccuuming.
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2009
    North Central Texas
    1,358
    You could get a "SlimeBag" to attach to a backwash hose to put the water back into the pool. That's what I'm going to do as soon as finances allow. Money, now, being used on new much bigger filter and flex hoses and fittings. I have to backwash, typically, every 2-3 days, because my old filter is so way undersized. And using cellulose, that filters so well, the filter fills up much faster than with DE and requires more backwash time to clean out filter.
    The bag will pay for itself pretty quickly especially if your cost of water is high.
    http://www.cleanerpools.net/
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    polyvue's Avatar
    Aug 2009
    1,215
    Though both vacuuming and use of a "slime bag" are useful to clear debris, only draining the pool will alleviate high levels of dissolved solids, including calcium.
    __
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by polyvue
    I so agree.
    OK. I am assuming that the stuff that is deposited on the pool is calcium. I am going to shock the pool to see if any of the cloudiness is the beginnings of other stuff.
    To avoid dumping so much water, does anyone know the dangers of having a high calcium level? My plan is to shock, floc, and then vacuum straight to waste because I have to dump water, and this will not keep blocking the filter every 5 minutes while at least achieving removal of the settled grit. So I will be dumping quite a bit of water (unknown of course), But what happens if the salt and calcium are say 1.5 times too high? If I can clear the pool and get the CYA, chlorine and TA levels and PH OK, but a bit too salty and with high CH, what dangers should I be looking at?
    Also, does anyone have a rough "formula" for using alum to flocculate?
    Nick
    polyvue's Avatar
    Aug 2009
    1,215
    High Calcium Hardness (CH) affects water balance and can lead to calcium deposits on walls, equipment and tile. You can get a good idea of the water balance by entering test results and pool size into the Pool Calculator. A high salt level is potentially corrosive to metals it comes into contact with: pool equipment (including heaters & ladders), concrete and plaster, and coping.
    Sorry, I don't know of a formula for using alum as flocculate nor of its advisability.
    CH - Calcium Hardness
    Calcium hardness indicates the amount of calcium in the water. Over time, water with low calcium levels will tend to dissolve calcium out of plaster, pebble, tile, stone, concrete, and to some extent fiberglass surfaces. You can prevent this from happening by keeping the water saturated with calcium.
    A plaster pool should have CH levels between 250 and 350 if possible. CH contributes to the CSI which indicates the tendency for paster [sic] damage or calcium scaling. You lower calcium by replacing water.
    __
    I figure the way this pool has been treated, I can't do too much harm with a few weeks of gradual lowering of the salt and calcium by natural attrition.
    So. Flocculate and vacuum.CYA then shock. I am not going to throw away water. If it goes pear-shaped then so be it.
    Nick
    OH WHAT? Now I am being told that I can't use the autovac to clean up the flocculant! This is all nonsense.
    It's just not worth it.
    Nick
