Results 1 to 7 of 7
Thread: Heating Pool during Fall and Winter
    We recently added a fiberglass pool (12,500 gallons) in our backyard. We added a gas heater so that we could use the pool year round. We live in Northeast Tennessee. We heat it up to 90 degrees each weekend. We turn the heater on Friday morning and it is ready by Saturday morning. Then, we turn it off on Sunday afternoon. We also recently purchased a solar cover to help retain some of the heat. Is it more cost effective to maintain the temperature at 75 degrees or some other temperature during the week and then increase the temp to 90 on the weekend, or better to just turn it off and only heat it up starting on Friday? Will the solar cover help? I am trying to find the most cost effective way to swim on the weekends.
    Thanks for your help!!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Heating Pool during Fall and Winter
    I think it would be better to leave the heater on as opposed to turning it off and on. (atleast for homes) According to my friend who works for the gas company when you turn your thermostat down in your home and you want to heat it back up again you are not just heating the air you have to reheat the furniture, walls, floor etc. so you wast a lot of energy reheating everything as opposed to keeping a constant temperature.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    San Rafael, CA USA
    12,082
    creechy,
    Welcome to TFP!
    It's more efficient (for a gas heater) to heat the pool only when needed. The reason is that the rate of heat loss is much higher when the pool is at higher temperatures. Of course, if the pool gets too cool, you may have to start heating it even earlier since it can only heat the water so quickly.
    X-PertPool,
    The guy at the gas company is wrong since whatever causes the heat to escape from the room is going to happen even if you keep it heated, except that the heat will be escaping even faster because the room is warmer. This is why you use a lot less gas maintaining a lower temperature than maintaining a higher temperature in the house. The rate of heat loss is proportional to the difference in temperature between inside and outside.
    Richard
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by creechy
    At one point I tried to maintain my 750 gallon in-ground plaster spa as I had an above-ground spa... heated and ready all of the time. I terminated this experiment in less than a week once I saw the amount of energy I was using. Though I don't have the comparative data to demonstrate the veracity of chem geek's reasoning, I believe it to be correct.
    Not only will the solar cover help, I would suggest that you have your pool covered every moment that you're not swimming. Though there will be some temperature loss via conduction to the ground and from the plumbing into the air, evaporative heat loss would be the largest contributor to cooling the water (and draining your pocketbook.) You may be able to retain some of that precious heat (energy) that you invest each weekend for the following weekend by keeping that solar cover on during the week.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mar 2009
    Charlotte, NC
    539
    Chem Geek is right, as usual.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Thank you for your help. I will just turn on the heater when we plan to use the pool and keep the solar cover on when we are not using the pool. I have so much to learn as a new pool owner!!
    Thanks again!!
    East TN
    Raypak Gas Heater
    This program will show you how much you save with a cover, among other things:
    nice-pool-heater-analysis-program-recently-posted-at-aquacal-t17852.html
    I direct you back to my post which has a link to the program.
    This is a really neat program!
    (I did not realize that AquaCal is a supporter of the board, BTW.)
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
