Thread: Above ground solar cover reel
    May 2008
    Fort Gratiot MI
    Hi everyone,
    A quick question. I have an above ground solar cover that is on a reel that is off the pool on two poles. This is the first year I have had it. I planned to keep the solar cover on the reel for the winter.
    Do I cover the solar cover with a tarp or just leave it uncovered and it will be ok?
    I live in Michigan and we do get alot of snow up here.
    Thanks in advance
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    Re: Above ground solar cover reel
    Quote Originally Posted by fixit5561
    I have an in-ground solar cover; it gets stored in the garage for the winter. Methinks covering it with a tarp is the next best option... if the snow and ice don't ruin it, the additional UV from six months of sunlight will certainly diminish its life-span.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    I take mine off every winter, fold it up and store it in the garage on a high shelf (so mice don't get it). Didn't remove it once - the next spring, the birds started to build nests in the ends before I ever made it out to get things moving on the pool - seems they like to get inside and build between the layers....what a mess, never again.
