Results 1 to 14 of 14
Thread: Chlorine Lock?
    Nov 2009
    MS Gulf Coast- Katrina Survivor - BP Hater!
    55
    Chlorine Lock?
    My pool is indoors and was cloudy/white 2 days ago. It's been beautiful for the last 3 months. I shocked w/recommended 12 to 16ppm FC w/6% for a cya of 35, ph 7.2. Water turned green and very cloudy. I kept chlorine level at 16ppm all day and night. Usually pool would clear up by now. Yesterday I upped the FC to the 24ppm for mustard algae per The Pool Calculator but overshot and at 30ppm and kept it there. Ph at 7.0 and aireating w/jets to bring that up. The water never turned white as I expected for dead algae. Expected to see clear water this morning but still green tint and fairly clear. Backwashed but very little came out. I added Super blue yesterday w/no results.
    Test results from 10-31 w/TF-100 kit
    15,000 gal
    1 1/2 hp Pentair pump
    Pentair Triton TR100 Sand Filter
    Heat Siphon Heat Pump
    fc-6.0
    cc-0
    tc-6.0
    ph-7.4
    ta-200 (high I know)
    ch-300
    cya- 35
    water temp- 90
    Any ideas? I'm suprised to see the green tint with such high fc. I've heard of chlorine lock but never experienced it. Pool owner for 30 yrs.
    Thanks
    15,000 gal Sun Fiberglass, Glass/Lexan/Aluminum Enclosed Room, 1.5 hp Pentair Whisperflow Pump, Triton 100- 600# Sand Filter, Heat Siphon Heat Pump, 3 Dbl. Seats w/8 Jets, Waterfall, 8' Interfab Slide, Pentair SAm Spectrum Amerlite Pool Light, Stenner MHP5 Chlorine Pump, Kreepy Krauly Vacuum, Bleach, 50 ppm Borates, TF 100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Chlorine Lock?
    With an indoor pool, unless you have a lot of glass around it, I doubt you have algae. Any chance you have copper in the water?
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Chlorine Lock?
    How do you normally chlorinate the pool? (SWG... liquid chlorine... something else?) What other chemicals do you add to the water? and how often?
    As John said, this doesn't sound like algae. Nor does it seem like chlorine lock (that would require much higher level of CYA... 35 ppm may be a bit high for an indoor pool, but the level of chlorine you report (6.0) is just fine.
    Don't know what effect Super Blue clarifier would have -- its MSDS is not forthcoming:
    http://www.poolspacare.com/app/msds/Rob ... erBlue.pdf
    Just trying to rule some things out. Might be helpful to be running the filter/pump for 24/7 a few days in a row and continue to backwash as needed.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Chlorine Lock?
    Is super blue a clarifier or algaecide?
    Chlorine Lock is pool store jargon/myth and entirely misunderstood. If your FC held overnight at shock level this isn't a typical algae issue.
    Yes, how do you normally chlorinate?
    When you say you shocked with bleach, it immediately turned green and cloudy? Are you sure you didn't use a scented variety or something?
    Nov 2009
    55
    Re: Chlorine Lock?
    I use walmart 6% unscented daily. I installed a new heater 1 week ago but it has a titanium exchanger. I'll have to go to lowes for a metal test strip. The poolhouse is glass w/lexan roof.
    Nov 2009
    55
    Re: Chlorine Lock?
    The Super Blue is a clarifier but I haven't needed it for a while. I think you're right about the metal. I'm on well water and haven't had to shock in a long time. Just picked up a sequesterant to add. It says its a blend of chelating agents. Hope it helps, I go out of town tomorrow for a week and was hoping my son would have an easy time keeping up the pool.
    Jul 2009
    London and France
    574
    Re: Chlorine Lock?
    Hi Captjohn,
    Did you get your test results back for metals?
    Along with others I doubt its algae, as you state you use well water I thinks you would be well (Pun) advised to have that tested properly so you know what you are dealing with.
    The green colour could come from manganese which is commonly found with iron (used to make green bottles so may give you a clue) in some well water.
    It could also come from copper, copper can deposit different colours depending on what compound of copper it is. Green would be produced if you were using hydrochloric acid (Muratic acid) as a PH reducer. If you add concentrated hydrochloric acid to a solution containing hexaaquacopper(II) ions, the six water molecules are replaced by four chloride ions.
    You may find the colour of the tetrachlorocuprate(II) ion described as olive-green or yellow. If you add water to the green solution, it returns to the blue colour.
    So it is a reversible reaction.
    Nov 2009
    55
    Re: Chlorine Lock?
    I haven't gotten the metal test done yet. I may have to do it today but I'm out of time. I leave today for a week. I added a double dose of regal metal out yesterday and been running filter 24/7 but it's not taking it out. I use muratic acid for ph and alkalinity control and citric acid for staining. I'll have to maintain Chem balance until I return. If no change by then a partial water change may have to be done.
    Chlorine level down to 8 and ph is 7.2 this morning. I will do a full test to see if anything else has changed.
    Thanks for your help guys. I'll keep you posted.
    Nov 2009
    55
    Re: Chlorine Lock?
    I'm home and no change, fairly clear and green tint. Sequesterant hasn't worked so I need to make a move. Nothing coming out of backwash. Added additional clarifyer yesterday (figured it couldn't hurt). I can't find anyone to test for metal.
    As teapot suggested, I may try a partial water change unless you guys have a better idea.
    polyvue's Avatar
    Aug 2009
    1,215
    Re: Chlorine Lock?
    Quote Originally Posted by captjohn
    Where are you located (city/state/country?) If you are in U.S. near a Leslie's store, I'd suggest calling and speaking with the manager. At my local Leslie's you have to beg a bit-- but they will perform tests for copper, iron and manganese. (On request only.)
    Have you had a chance to perform an overnight chlorine loss test?
    See Perform the Overnight FC Loss Test
    __
    Nov 2009
    55
    Re: Chlorine Lock?
    I'm on the MS gulf coast and I haven't heard of a Lesley's in my area. I haven't done the actual chlorine loss test but my loss has been very minimal. I haven't added chlorine for over 5 days and it was 8ppm today. It's clearing up slowly. I think the chlorine was too high when I added the sequestrant last week but I had no choice. It may have offset it's effectiveness. I have another bottle and I'm waiting till it's below 4ppm to add it as per instructions. I'll have to search for someone to test for metal but I think I have it going my way for now. I was using sequestrants regularly for staining but I kept getting stain so I stopped. I had to use citric acid anyway to rid the stains so I figured I was wasting money. I think it was working better than I thought! I'll post an update tomorrow. I warmed it up today to swim for Veterans Day, god bless them all!
    polyvue's Avatar
    Aug 2009
    1,215
    Re: Chlorine Lock?
    If any of these stores are near you, they might be able to test for metals...
    Leslie's
    61123 Airport Rd
    Slidell, LA 70460
    985.641.2371
    Leslie's Swimming Pool Supply
    312 Schillinger Rd S
    Mobile, AL 36608
    Miles Pool Supplies
    3724 Highway 15 N
    Laurel, MS 39440
    601-649-7665
    __
    Nov 2009
    55
    Re: Chlorine Lock?
    Great. I'll check Slidell. Didn't know they existed.
    Thanks!
    Jan 2009
    Cupertino, CA
    1,966
    Re: Chlorine Lock?
    Also, sometimes a large hardware store may have test strips for metal; I can't put my hands on it right now but my Home Depot had a package that included at least iron and copper tests, and probably a couple others.
    --paulr
    BBB "Intermediate Swimmer"
