Results 1 to 9 of 9
Thread: Finally, a desirable solution... PICS.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    The History:
    first-test-with-tf-100-t11452.html
    the-infamous-stains-before-treatment-pics-t14861.html
    pb-has-offered-new-reason-for-pool-stains-what-now-t16875.html
    Hello all,
    I wanted to post an update on the final resolution with the PB. After extensive research, endless communications with members on this forum, and persuasive communications with the PB, I hopefully have come to a desirable solution for my pool. I have posted the above links for the history of my dilema. In the end the PB agreed to replaster the pool with Pebble Tec in order to resolve the issue. Here are pics of the process and final results.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    chris4150's Avatar
    Apr 2009
    180
    Re: Finally, a desirable solution... PICS.
    more pics of process
    chris4150's Avatar
    Apr 2009
    180
    final product pics
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    All's Well That Ends Well... someone famous once said. A great looking lagoon pool.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    So delighted for you!! Looks awesome now..NO STAINS!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    chris4150's Avatar
    Apr 2009
    180
    Thank you for the replys. Pices, I just viewed your pool build pics, very nice pool. I like the Pebble Tec color you chose. I want to go swim in my pool but the temp here has dropped so naturally the water has as well.
    Aug 2009
    North Central Texas
    1,358
    Beautiful
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Casey's Avatar
    SW PA
    10,418
    Your pool looks great!
    So glad you got it fixed and it's up to snuff!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    A happy ending, long time coming. Good for you.
