greg,
Thanks and no. I dont remove anything on the skimmer. I just drain the water down and then when I blow the lines out, I connect a pipe to the skimmer hole and shoot air through it that throws it up back into the pool. I do the same thing while I add pool antifreeze. It turns pink and then I know there is antifreeze in the lines. Looks like and L is all. Great tool with only a couple fittings and some inch and a half pipe. Then I plug the hole in the skimmer with my gizmo, and put a half emply bottle of antifreeze upside down in the skimmer. Then I take ducktape and tape the skimmer cover edges so that no rainwater gets in there. For an extra measure, I take some landscapping plastic and lay it over the top of the skimmer cover and then put a 2 ft sqare piece of plywood over the top of it with a large rock on top. That way no water penetrates it at all.
Thanks on the topiary. Yes I trim it about 3 times each spring-fall. In the fall I let it grow out some because of the cold during the winter. That way when I trim it in the spring, it gets ride of the dead look and the green comes out faster.
Hope that helps!
Chad
Hope that helps!
Chad
