Thread: EZ POOL and new pics
    http://s742.photobucket.com/albums/x...andjerri27298/
    Ok I give. EZ Pool might not be the best way. If I want to switch from EZ Pool, what would I switch to and how would I switch? I have read about the transition to BBB but what about other chlorine.
    Oh another update: PB says concrete guy is suppose to clean up edges of deck and fine grade...concrete guy says its not him... now it looks like I've got to pour more money into the hole for grading. AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    Grant and Jerri
    Liberty, NC
    New 18x36 vinyl liner pool with lighting and fountain
    30,403
    Re: EZ POOL and new pics
    There's really no "switching". BBB is completely about testing your pool accurately, knowing what to do with the test results and not putting things in your pool you don't need.
    BBB can use Clorox, liquid chlorine, Cal Hypo, pucks....all forms of chlorine......it's understanding the advantages and drawbacks of each one that make you a good BBB'r.
    I'm sure your hands are full right now getting your pool built but read some of the first articles up in Pool School.....there's one specifically that overviews BBB. That'll help get you started.
    May 2009
    Enterprise, AL
    54
    Quote Originally Posted by GrantsPool
    Unless you hired the concrete guy yourself, he's a sub for the PB and the PB needs to work it out. The amount of finish work (fine grade, etc) should be in the contract with the PB. How it gets done and who does it is his responsibility! Shouldn't cost you more to get the work you contracted done!
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    How much EZPool is in the water?
    Since this is a new build, have you already added chemicals?
    If so, I can't imagine the copper levels are very high yet, so I'd just go ahead and begin using chlorine instead. Just read up on the various forms of chlorine so you can have the knowledge to go along with your proper testing....that's the key to TFP - proper testing and the knowledge to know what to do with the results.
    You can take a water sample to a pool store to have them test for copper levels, if it's higher than say .6-1ppm then I'd go ahead and replace some of the water.
