Results 1 to 7 of 7
Thread: Fixing a leaking underground Pipe without excavating
    Oct 2009
    Concord,CA
    6
    Hi, I would like to find if anyone has used the Pipes Down Under Trenchless Repair system here there website http://pipesdownunder.com/home.html we have a leaking or offset pip underground just wanted know it this would be safe. Any help would appreciated
    Thanks
    10K gallon IG Fiberglass (Viking); Jandy AE1500 HP; Hayward CA4025 Cartridge Filter; Hayward CL200 Automatic Chlorine Feeder; Solar Blanket; Hayward 1 HP Super Pump; Hayward Aqua-Rite SWG (T-3 cell)
    22,598
    Re: Fixing a leaking underground Pipe without excavating
    Marketing hype being what it is. If you can afford to loose 3/8" diameter in your piping it looks like it could work. They say it's smooth bore so that's good news. In situations where there is going to be signicant costs and/or damage repairing the conventional route I'd definitely give it a try.
    30,496
    I have the same take on it as 'bama. No reason why it wouldn't work (how many turns do you have?) but don't discount the 3/8 reduction (probably more like a 1/2")....that's significant.
    I would also be triple-slam, dead on positive that was the source of my leak, too. Probably 95% of pool leaks are not in the underground piping.
    Guest
    I've seen the product, and my concern is the pipe diameter reduction as well, especially in the 90's. I could see the potential for an almost "flat" section as it made its way through. That would not be good
    From my experience, duraleigh's observation is also accurate ("I would also be triple-slam, dead on positive that was the source of my leak, too. Probably 95% of pool leaks are not in the underground piping.").
    Seems to me that the options to repair something that is easier than the "proper" fix always produces a downside for the ease of repair! If it was me (for whatever that's worth!) I'd locate the leak and make a hard repair. Then it's done and you won't ever have to worry about it again. Can't say I'd be able to feel the same way with this repair system!
    Bruce
    Oct 2009
    Concord,CA
    6
    Hi, thanks everyone for the help. We have 2" pipe coming from where the leak is at, how much reduction in flow would we have are pump is a 3/4 H.P. Pentair Whisperflo WFE-3
    Thanks
    South Central NJ
    3,192
    One thing I concerned about is that the picture showing the insert through an elbow is NOT using a Schedule 40 elbow. Schedule 40 elbows are a much tighter turn. Schedule 40 is what is normally used in PVC pool plumbing because it is pressure rated. What they used is for drainage applications. It's not nearly as strong.
    Here's the picture:
    http://pipesdownunder.com/images/330_thekitelbow.jpg
    Next time you're in Home Depot or Lowes, look at the drainage and Schedule 40 90 degree fittings. You'll see what I mean.
    One of the most frequent failures of a pool line is a skimmer line that used flex. The homeowner put his tabs in the skimmer basket and over the years, the tabs made the line swell and eventually either clog up or collapse. This method of repair will result in failure.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    Jul 2011
    East Providence, RI
    17
    I know this is an old thread but I wanted to Bump it to see if anybody had tried Pipes Down Under? As I close in on a return as the source of my leak I'm considering it as an option.
    Also, It seems to me this solution wouldn't work for the skimmers as the pipe would get sucked closed. Does that makes sense?
    38,000 gallon In-Ground, gunite bottom/fiberglass wall (older style I've not seen elsewhere)
    Sand Filter, Hayward 1HP SuperFlow 2 (not sure flow rate)
    Built @1980
