Thread: Winterizing Liquidator ??
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    Any tips for cleaning LQ for winter?
    I have WS or scale on inside walls at the bottom half where liquid chlorine collected. Not at the top area where the chlorine was diluted
    I imagine there may be some build-up / scaling on inside of tubes and valves. (Although maybe not since i didnt have scale on upper part of LQ)
    I was thinking of soaking everything in some type of diluted acid solution
    Any guidance?
    PS on different item: to store for winter, rubber o-rings, should one use teflon spray or silicone grease? I have seen both mentioned in different posts
    Mar 2007
    Virginia Beach
    272
    Re: Winterizing Liquidator ??
    I've gone through a few winters with mine and haven't done a lot to mine other than basic cleaning. I pull it out of the pool set up, hook the hoses from the inlet to the outlet and use the flow control to shut it off completely. I spray the crud out of the LQ do a basic scrub down and the put it in the attic for the winter. I would unscrew and examine your float assemblies over the winter and see if there is any degradation around the screw post. If so, I'd reinforce them with epoxy: reenforcing-the-liquidator-float-assemby-t11039.html
    It's cheap and a lot easier then paying $30.00 per assembly to replace. Lastly I would replace the hoses every other year.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Aug 2007
    Austin, TX
    343
    No issues here... about to go through another two nights of freezing temps
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mar 2007
    Virginia Beach
    272
    Used to be that I'd disconnect the LQ during the winter. This year I left it hooked up. I've had no issues.
    Liquidator
    22,551
    Well, since we've opened this old thread. I left mine hooked up and running at a much lower flow than during the summer and it's faired fine during the very cold (I know you northerners are laughing at that) days we've had.
