Thread: Filter pressure gauge in the snow belt
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Should I take it off for the winter and store at room temp, or is it OK to leave it there? I assume there's no water or humidity in the brass connector and T, but who knows for sure?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Mar 2007
    Ontario
    211
    Re: Filter pressure gauge in the snow belt
    I have always unscrewed gauge, and the site glass as well. Don't know if needs to be or not.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I've never had one survive the winter outdoors. I bring it inside.
    South Central NJ
    3,192
    I remove them from Haywards and Pentairs and put them in the pump basket. Jandy's and Waterways get left alone.
    Always remove threaded sight glasses. Those with screws through the center are left alone but I make certain there is no water in them.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Seems that Murphy's Law should be applied:
    MURPHY'S LAW: If anything can go wrong, it will.
    Murphy's First Corollary: Left to themselves, things tend to go from bad to worse.
    Thanks for all the responses.
    Oct 2009
    Marriottsville, MD
    17
    We definitely get ice / snow / freezes here in MD, but we've never had anyone closing our pool in the past remove the gauge, and I wasn't planning to this time... If it matters, ours is mounted vertically on top of the filter canister and doesn't seem likely that more than a few drops of water would stay on it, much less cause a problem.
    22.5k gal. (est.) IG Dark Plaster Pool (2007)
    Jandy Stealth SHPM 2.0HP Pump ~100gpm
    Jandy CL460 Cartridge Filter
    Polaris 9300 Bot/Cleaner
    Jandy AE-Ti AE2000T Heat Pump
