Results 1 to 7 of 7
Thread: Backwash DE filter prior to closing?
    I am having my pool closed for the first time on Friday. The ladies at the pool store have advised me to have the water lowered to 4" below returns prior to my appointment. I have read that a DE filter should be backwashed prior to closing, yet when i am asked them they said no.
    So what is correct? Is the pool guy going to show up and want to backwash my filter after i have already lowered level, thereby causing the level to be lowered more?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Backwash DE filter prior to closing?
    Use the backwashing process to start lowering the water level. Closing would be a good time to open the filter and clean and inspect the grids so you are ready to go in the spring.
    Mar 2007
    Coastalish 'down easter'
    4,160
    John is perfectly correct!
    You want to take the DE filter apart at least once a year and fully/properly clean it! Doing it on closing means that you will be all set to open the pool and swim come next spring
    Luv& Luk
    -Ted
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Since you guys are at it, what's the proper dilution factor for cleaning the filter with muriatic acid? I saw some copper tubing inside.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Mar 2007
    4,160
    I think the standard is 10:1 for a few hour soak, I use closer to 25:1 (water: acid ) because I soak them for 10 - 16 hours at a time and don't want the acid to attack the metal nuts and bolts and washers that hold them together
    PLEASE also remember to do the degreasing soak PRIOR to acid washing them!!!
    Luv& Luk
    -Ted
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by waste
    Degrease what and with what?
    Mar 2007
    4,160
    Before! you put the grids/ fingers - filter elements into an acid solution, degrease them in a solution of either electric dishwasher powder or TSP (Tri - Sodium- Phosphate). 1 cup of either per 10 gal. water should be enough. Allow a few hours to soak, agitating the mix certainly wouldn't hurt , rinse them and then put them in the acid mix.
    Unless you have calcium in the water, many pools do, you probably won't even need the acid wash {Chem 201 moment (not that I'm qualified ) - acid coagulates oils on the membranes, causing worse clogging than you started with and acid only attacks metals, like calcium, that are congesting the membrane }
    The thing to look for before doing a chem soak, is how well the membrane is letting the water flow out of it, after you've rinsed them with the hose (if they still hold water for ~ 30 seconds, it's time to soak them).
    I hope this clarifies what I didn't say in the earlier post
    Luv& Luk
    -Ted
