Results 1 to 8 of 8
Thread: New Pebble Tech from plaster. Is maint and care the same
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    Hello to all,
    I recently had my pool redone with Pebble Tech and was wondering if the care is any different from when I had plaster. I have already added Jacks Magic Magenta and havd already tested the PH which needs to be brought down. Is the hardness demand going to be different than plaster? Look forward to the replys.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: New Pebble Tech from plaster. Is maint and care the same
    Quote Originally Posted by chris4150
    Hi Chris,
    My understanding is that the hardness demand is very similar if not the same as with a plaster pool. You indicated that the Pebble Tech surface was recent; presuming that it's older than a month -- or at least beyond the initial treatment indicated by the manufacturer for that type of finish. The main thing is to brush the sides and floor at regular intervals and keep the water chemistry right by making needed adjustments for a plaster pool, per Recommended Levels
    Now, we'll see what the Pebble Tech owners say...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Guest
    Your acid demand will go up, especially if you are using a SWCG. Do not add any salt for the first 30 days (and preferably 60 days) if that is the case. Once you have passed the 60 day mark it is safe to add your salt. I also use dry acid in my pool as opposed to liquid. My thought is that it is easier to store and does not "sour" like I feel liquid can. Watch for clumps if you use dry and broadcast the acid around the pool when it is running. It will dissipate before it hits the bottom and will not mark the finish like it would a plaster pool.
    You should love the look and strength of your new finish! Congrats!!
    Bruce
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    We don't usually recommend the dry because it increases the sulfate level.
    If you are comfortable with adding Muratic Acid (with the pump running), that's the route we usually advise.
    Guest
    Quote Originally Posted by frustratedpoolmom
    I tend to use the dry for ease, and I just don't like having the liquid sitting around (I guess I'm weird that way!). You are correct on raising the sulfate level though, and I apologize since I do know that goes against the grain of this site
    The liquid will do the trick, but PebbleTec will handle the dry from a strength of product standpoint (I think that was kinda the bigger point I was trying to make, but I didn't do it very well).
    chris4150's Avatar
    Apr 2009
    180
    I appreciate the input,
    Ive always used liquid MA and applied such last night. I went ahead and did a light brushing of the pool, not sure if this was necessary or not. I read on the Pebble Tech website that they recommended not introducing any chlorine to the water until my PH, TA, and hardness was at the lower range of thier recommendations. I have noticed that my pool water is a bit cloudy right now. I plan on cleaning the filters this evening but Im wondering if this will reduce the effect of the Jacks Magic Magenta that I added two days ago. I look forward to yalls input.
    Chris
    11,969
    Chris
    How are these levels? That could explain the cloudiness. I would think you can add a minimal amount of chlorine 1-2ppm at a time without causing problems. I know you not supposed to shock with new plaster but no chlorine isn't a good idea either.
    Not sure why cleaning the filter would affect the Magic, but you can always add another maintenance dose, I would think. What does the bottle say?
    chris4150's Avatar
    Apr 2009
    180
    Hello Frustrated,
    The insturctions on the Jack's Magic suggests that you can use the product for maintanance purposes in additon to start up or new plaster. It doesnt make any suggestions in regards to the amount of time one needs to allow before doing any filter cleaning. Ill provide current readings on the pool chemistry as soon as I get home. I did an initial PH test before adding the initial dose of MA and it was pretty dark, most likely above 8.2. Talk to you then.
    Chris
