Results 1 to 7 of 7
Thread: Waiting to replaster...dangers?
    Jul 2009
    Martinez,Ca
    9
    Hello....
    First a quick thanks to all who helped me convert to BBB, yes I added Borax/Acid, months ago.
    Just yesterday I got another " it's so clear and SOFT " compliment. LOVE MY TROUBLE FREE POOL.
    We inherited this pool 6 months ago when we bought the house. We live in Nor Cal so we will use it year round. Mostly now using the heated spa that spills over into the pool, all the same water. We don't heat the pool. We were told by the neighbors that for years it was empty and used as a skateboard park. There are a handful of 6 inch areas on the bottom where the gunite/plaster is worn through and the under cement is exposed. The finish is gone and the pool has a "surface of the moon" look to it , which we have come to like, especially at night with the pool light on.
    MY BIG QUESTION: ( and it's financial) What are the dangers of delaying resufacing? Or is it mostly just a cosmetic issue ? Thank You.
    Ross Biondo
    16,000 gal ,plaster , cartridge filter, IG pool with aerated spillover spa.
    Aug 2009
    North Central Texas
    1,358
    Re: Waiting to replaster...dangers?
    I can't really comment on the "dangers" but a friend of mine, who has a plaster pool, had a few spots in her plaster that popped out exposing the concrete; some on the bottom and some on the bench; I think a couple more on the steps. That occurred about three years ago. This is the original plaster installed in 88. Otherwise the plaster looks great and is uniformly white without any cement showing through. Although her pool is a decent size it is a "play pool", about 48" deep, uniformly.
    This summer she had a part-time pool guy, who maintains a few pools including hers, a retired "geezer", patch the places, done with water in the pool. Not sure what product he used. You can't even tell the patches are there.
    I had my pool replastered, with blue plaster, which cost more, in 96 and it cost about (ONLY) $4600. I've seen, here on the boards that it is at least twice that much now. OUCH.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Plaster is the "sealer" that keeps the water in. If you have spots where the gunite is showing thru, then there is a chance that you may begin to loose water (because the gunite can transmit water). Also, if this traveling water makes its way to any rebar, it will begin to rust and it will show. Third, when you do re plaster, you have to be concerned with ground water (when the pool is empty). Make sure your contractor is knowledgeable about this BEFORE he drains the pool, and make the appropriate preparations.
    Are you above or below in Martinez?
    Factory Warranty Station for:
    Jul 2009
    Martinez,Ca
    9
    Pool Clown...
    Above or below 'what' in Martinez ?
    Ross Biondo
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    The water table...
    Jul 2009
    Martinez,Ca
    9
    Pool Clown.....
    We are very much above the water table.
    We are on a ridge with a small lake about
    100 ft away and 30 ft below us.
    Ross Biondo
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by ross5928
    Pool Clown.....
    Sounds like you would be ok. Make sure the plasterer/PB is aware of water table issues anyway, just to be safe.
