Results 1 to 8 of 8
Thread: Can't find on search... mosquito control, citronella, vodka
    I am trying to find a post, perhaps by geekgranny, that detailed how to make a homemade mosquito repellant from vodka and citronella oil. There may have been some other items in it, I can't quite recall. I did search, not sure if maybe it was a thread that later got pulled for some other reason. Really wish I'd written it down at the time.
    Advice, anyone?
    Re: Can't find on search... mosquito control, citronella, vodka
    If you drink enough vodka, you don't care if the bugs are biting
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    There's a thread on Mosquito control, but it doesn't talk about vodka. If you search on "mosquito", you'll get more hits, but again, no vodka and nothing on this topic posted by geekgranny.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by The Mermaid Queen
    Now that's what Beave and I call "Vodka Logic".
    Quote Originally Posted by jdizon
    There are a couple of different formulations you can make for your natural mosquito repellent. In general, what you are doing is diluting an essential oil that the mosquitoes find distasteful or which confuses them so they can't find you to bite you. The oils don't mix with water, so you'll need to add them to other oils or to alcohol. It's important to use an oil or alcohol that is safe for your skin. Also, don't go overboard with the essential oils.
    Thanks. what I think I recall is some amount of vodka mixed with only a few drops of citronella oil. What I don't know is if that is the stuff I use in the torches. Maybe the torch oil is just lamp oil mixed with a more pure citronella oil and that more pure stuff is what I really need.
    I don't want to be using lamp oil if that is not right, can't be good for my skin.
    I'll try an internet search for pure citronella oil next, maybe that will give me a clue.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    [quote="anonapersona
    [/quote]
    You want the straight citronella oil, not the lamp oil.
    So, where does "straight citronella oil" come from? The essential oil aisle at the healthfood store?
    SW Indiana
    9,199
    You used to be able to buy it everywhere as an insect repellent. Amazon carries it. From what I recall, to be effective it has to be reapplied about every 20 minutes.
