Results 1 to 8 of 8
Thread: Cancun, Mexico pool water test results.........
    cancuntom's Avatar
    Mar 2009
    Cancun, Mexico
    45
    Just got my Trouble Free Pool Test Kit TF-100
    I live in Cancun, Mexico. My pool water is clear and clean looking and the PH and Chlorine levels are checked every other day and adjusted on an as needed basis. I now have this data from the kit but do not know how to interpret it. Could someone comment on the data for me? .........Thanks in advance.
    Date: Oct.24,2009
    FC= 2
    CC= .5
    TC= 2.5
    pH= 7.5
    T/A= 200
    CH= 350
    CYA= 90
    Temps= Air 84ºF
    Pool Water 84ºF
    cancunTom
    Pool size: 14,300 gals. in-ground
    Filter: Aster99 Sand
    Flow: 22m3/h
    Construction: concrete block/Stucco/Glass mosaic tile
    Pump: 2hp, 3450rpm, 220V
    Heater: RayPak P-R206AE
    Check out our Mexican Adventures on my Caribbean Webpage & leave a comment! http://www.cancunTom.com
    Aug 2007
    near the swamp
    806
    Re: Cancun, Mexico pool water test results.........
    Right now you should start shocking your pool.
    Mar 2007
    San Rafael, CA USA
    12,082
    Assuming that you were using a 10 ml sample for your chlorine test, the 0.5 ppm CC isn't a problem since it's really "<= 0.5 ppm". You could redo the test using a 25 ml sample where each drop counts as 0.2 ppm (instead of 0.5 ppm) since I suspect your CC is probably < 0.2 ppm. So I don't think you need to shock.
    On the other hand, your FC level is too low for your CYA level if you want to make sure to prevent algae growth. Assuming the CYA reading of 90 ppm is correct, then you should shoot for a minimum FC of 7 ppm. If your pool gets a lot of direct sunlight, then a higher CYA level is OK, but 90 is probably too high. Something in the 60-80 ppm range would be better. Not a huge deal right now so you can just let normal water dilution take care of that. Just don't use any stabilized chlorine (Trichlor or Dichlor) or else the CYA will get higher. If you regularly backwash your sand filter, then I would expect the CYA to slowly drop over time.
    Do you use any algaecide or phosphate remover in your pool or do anything else to prevent algae growth? If not, then you've probably got a pool low in algae nutrients (i.e. you are lucky). You can definitely keep algae from growing using chlorine alone, but I wouldn't take a chance with the low 2 ppm FC level you currently have.
    As for the other measurements, you can use The Pool Calculator to calculate the saturation index which in your case is +0.40 which is on the high side so could cause some cloudiness or scaling, especially if the pH, TA or CH were to continue to rise. The high TA you have would normally lead to a tendency for the pH to rise over time (especially with aeration) unless you were adding something to the pool that was acidic. If you find that you are regularly adding acid to the pool to keep the pH down at 7.5, then you could just keep doing that and the TA could get lower over time. However, if you have a lot of evaporation and refill and if the water is high in TA, then the TA could continue to climb (same with the CH). Use of a pool cover would virtually eliminate such evaporation. I suggest you test your tap water with the TF100 kit to see its TA and CH levels (no need to test for CYA -- there won't be any). If you want to lower the TA, then you can follow the instructions in Lower Total Alkalinity.
    Richard
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by cancuntom
    FC= 2
    CC= .5
    TC= 2.5
    pH= 7.5
    T/A= 200
    CH= 350
    CYA= 90
    Temps= Air 84ºF
    Pool Water 84ºF
    May I just meditate on your pool water temperature for a little while? ...
    All done, thanks. Our water is 64ºF here on the frozen tundra that is Northern California (you mid-westerners keep quiet -- it's my turn to complain!)
    There's nothing I have to say that could improve on chem geek's analysis, so I would just suggest that if by whatever means you reduce CYA you can safely operate at a lower level of chlorine (2-3 ppm Free Chlorine (FC) works with 30 ppm Cyanuric Acid (CYA)).
    Add liquid chlorine for sanitation, and if you have any more of those Trichlor pucks handy, use for skeet. Do not attempt to smoke them -- there's no amount of rub that will make them taste good!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    30,432
    Well, I sure enjoy "piling on" when it's mostly all good news!!
    That your water is clear and you check the CL and pH as often as you do is a really good indicator of the condition of your pool......you obviously take good care of it.
    Just repeating from above, I would reduce the CYA down thru dilution to around 50-60 max (I am assuming you do not have an SWG) and then run the chlorine just a little higher....around 3-5ppm.
    Conversely, leave the CYA alone but boost the chlorine up to around 5-8ppm. Reducing the CYA is more trouble at first but will make it easier in the long run.
    Please do not post your water temperature for the rest of the winter or you may end up with some visitors!
    cancuntom's Avatar
    Mar 2009
    Cancun, Mexico
    45
    Thanks so much for the input. Some of it is a bit over my head but I shall study it and figure it out.
    Dualeigh
    ..........(Close your eyes before you read that it is 10:21AM Tuesday Oct.27,2009 and that the air temp is 84.2ºF and the pool water temp is 85.3ºF.....a quickie tropical rain storm just passed through and knocked the air temp down a bit)
    When we get bored with our garden pool we to go to our "BIG" pool along with some friends:
    cancunTom
    Flow: 22m3/h
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Now you're just being mean.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ahh, I here I thought our backyard oasis was nice
    Tom, you have gotten great advice so far..no need to shock, but please get that FC level up per the CYA/Chlorine chart in pool school.
