According to this link, the CYA mixing bottle is filled with 7mL pool water, and then another 7mL of R-0013:
http://www.taylortechnologies.com/Chemi ... ntentID=44
But in the TFPkit, the sticker label on the mixing bottle uses much larger liquid amounts. Using one of the measuring cylinders, the bottom line is measuring about 15mL, and the top line is about 30mL.
Seems following Taylor's instructions can save a lot on R-0013 use. Am I misreading something here? Is the sticker on my mixing bottle just misplaced?
Edit: The comparator tube in the TFPkit is also marked "Taylor" so I assume it's the same tube included in the K-2006 kit.
