Thread: Chlorine test comes up almost red?
    I'm in Ontario, so we'll be closing in the next week or so. I've had the heater off for a couple weeks and the water is about 60. I had also turned off the SWG as well and it had been off for a week or so. The solar blanked has been on this whole time as well. In any case, I flicked it on for a couple hours yesterday (the SWG) and today I tested the chlorine level as I'm not too sure at which temperature I no longer need to worry about algae. Anyhow, it's usually a mid to dark yellow, and today it almost look red. Any ideas?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Chlorine test comes up almost red?
    Quote Originally Posted by jonmar
    Others will correct me if I'm wrong but I think algae could still be a danger at 60° F. Not applying chlorine doesn't automatically mean that your pool will get algae, but it makes it more susceptible. What type of chlorine test are you performing? OTO (different shades of yellow)? DPD (different shades of red - from yellow/orange to deep purple)? Is there a number on the side of the comparator that corresponds to the shade you're seeing? E.g. 3 ppm, 5 ppm... 10 ppm.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mar 2007
    Coastalish 'down easter'
    4,160
    Sounds like you're using the OTO cl test and the chlorine level is 10+.
    If you want to test this, you can dilute the pool water 1:1 with unchlorinated water, test that sample and multiply the result by 2 to get a pretty good idea of the actual chlorine level.
    I'd leave the SWCG off for now Sounds like you've got ~ nothing in the pool to consume the chlorine and the solar cover is keeping the sun from burning off much of the chlorine you have
    Luv& Luk
    -Ted
