laurandavid09 said:
TH-looks like around 200-400, it is a light purple color.
FC-Bromine-0/0
pH-7.8-8.4. Bright pink color
TA-180
CYA-0
laurandavid09 said:
I have also been running my pump all the time. Now that I am getting stuff to normal, can I just run it during the day and leave it off at night?
Not exactly sure what your goal is here. I believe that in another thread you mentioned that your pool was green, so are you trying to fight algae?
As you may have already surmised, test strips can be maddeningly imprecise (and have been known to be inaccurate) but if you believe the results, there are one or two things you can do even without more accurate testing.
1) Reduce the pH
Using the
Pool Calculator determine the correct amount of Muriatic Acid (MA)
to reduce your pH from (let's say, 8.0) to 7.3
2) Increase Free Chlorine (FC) to 3.0 ppm or higher using liquid chlorine or 6% bleach
You can use the Pool Calculator to determine exact amount
Add the MA (acid) while the pump is running, the liquid chlorine 30-60 minutes later, and then let the pump run another 30-60 minutes to be sure both are distributed throughout the pool. You don't have to leave the pump on 24/7 unless you're in the midst of shocking to kill algae or have some other reason to leave it on.
