Thread: return line is a "Geyser"
    mred's Avatar
    Sep 2008
    everywhere
    29
    trying to fix my return line.
    some one stepped on my jandy valve that is in line to return to the pool.
    so i am having to cut the vavle out which is tied to a 2" 90 that goes straight in to the ground.
    so i dig the ground just enough to where i can cut the bottom side of the 90.
    i cant clue on a new 90 because of the water that just keeps running out
    what the heck,do i have to let the water out till its down past the returns?
    Ed
    "Dry Gun" inground, Hayward 6020 D.E.,1/5HP
    30,000
    Aug 2009
    North Central Texas
    1,358
    Re: return line is a "Geyser"
    Bummer. Do you have any plugs for the returns? If not do you have a pool store near by you could "run to". Be careful of using something not intended for plugging the returns as it/they could get sucked through and clog the pipe.
    Last week I picked up some replacement return fittings at Leslie's that have several different size/type eyeballs included. One had no openings and is typically used for pressure testing but it is designed for pressure coming into the pool and not going backwards so it might not work. Also, if you have "standard" return fittings be sure and pickup the little tool that takes out the screw in fitting that the eyeball and outer ring screw on to.
    You could maybe put a cork in the eyeball return, if that is what you have, but you'd have to make sure the part of cork that sticks out is big enough that it won't get sucked in.
    Hopefully someone will see this soon and respond. Good Luck. Sorry for your "disaster".
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If the cut is below the water line you'll need to plug the returns and set your multiport (if you have one) to the "closed" position.
    mred's Avatar
    Sep 2008
    everywhere
    29
    some quick thinking, i tied a string to a rag and stuffed it down the pipe,and had to work fast.
    thanks
    Ed
    30,000
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Old guy trick: Use a few pieces of bread. But you gotta work quick, and in the end, the bread gets soggy and passes, without having to deal with a plug that may be in too far or too tight.
    Just a clown talking...ignore him.
    Factory Warranty Station for:
