Thread: rough plumb drain question
    A contractor friend told me that our drain shouldnt be tilting away from the house (only slightly) as the drain slope runs the opposite way. I question his logic as our drain is pump driven, n ot gravity driven right?
    Please let me know ASAP!
    Thanks in advance!
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    22,553
    Re: rough plumb drain question
    You mean the drain is physically not level?
    The drain should be level with the bottom of the pool regardless of which way the line is sloped.
    The up spout is not verticle but leans slightly north ( just a few degrees). This is the tough plumb prior to gunite
    mas985's Avatar
    Pleasanton, CA
    11,743
    If the pipe has a slight slope it shouldn't matter that much unless it affects the placement of the cover. The cover should be even with the bottom of the pool. Like you said, it is pump driven so it really shouldn't matter.
    Mark
    South Central NJ
    3,192
    It's important for the drain POT to be level or the cover mounting ring used with a hand formed pot to be level. This keeps the drain cover level. The actual line itself is less important in terms of being level and plumb as it makes it's way to the equipment pad.
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
