Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Please send me Pics of Intellibrite Lights
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    So we did a NO-NO and placed our pool light under a sheer descent which faces towards the house. I am considering an LED light for my pool. I have a 300w pentair # 78928500 and the pool light faces the house. The glare is bothersome so I am hoping that replacement with an LED would have less glare. I have a lens cover on it and a dimmer switch however I am still not happy with it. Please I would like all who have Intellibrite lights to send me pics so that I can see if the glare is cut down. These pics must be looking directly at the light . My email is vat-19@juno.com. I hope that I have explained properly. Any suggestions short of installing another light on the opposite side would be appreciated.
    Thank you for taking the time to look into my inquiry.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Please send me Pics of Intellibrite Lights
    Hi Brent,
    I don't have this information handy, but you might want to determine exactly how bright the installed 300 watt bulb is in your pool, then check out Intellibrite and other options you're considering, including installation of a lower wattage lamp of the same type currently in use. The lights and/or bulbs should have published data associated with them that describe a.) color temperature (in kelvins) and b.) lumens. You'll want a bulb that produces less of the latter! Check out the links below for more info.
    Greg
    http://www.buylighting.com/Swimming-Poo ... -s/218.htm
    http://en.wikipedia.org/wiki/Color_temperature
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Aug 2009
    North Central Texas
    1,358
    Try this link that is a discussion here on TFP. Scroll al the way to next to last post lwhere I've posted some pics of my ColorSplash replacement bulb.
    http://www.troublefreepool.com/do-i-...ow-t16964.html
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Gregg this is a pic of my light and notice the glare
    polyvue's Avatar
    Aug 2009
    1,215
    Yes, I see what you mean. I seem to recall that your pool is only about 10' wide at this point, right? So we're looking at the light from only that distance... I think that explains the glare. It probably even bounces off the other side to create more glare. Still not sure why using the dimmer doesn't greatly improve the situation -- but it then may not provide enough light for other parts of the pool. I would reduce the wattage of the bulb, then consider environment lightage in your "bird cage" to make up the difference.
    __
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by Brentr
    You can see very well the excellent dispersion from my pics of LED in my link above as compared to the pic of your incandescent light. The incandsecent has blare/glare yet doesn't spread the light well much away from the light fixture. That's a major thing I was raving about in my posts.
    gg=alice
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Alice I still cannot see your pic. Believe me I would like to replace it with a color splash because this would be the easiest and the least expensive however can you send a pic to my email at vat-19@juno.com
    Thanks in advance
    Greg do you think by going with an LED that has different colors might reduce the glare. The pic you see has some duct tape on the upper half of the blue lens cover.
    Thanks in advance
    polyvue's Avatar
    Aug 2009
    1,215
    Thanks in advance
    Maybe... I have Hayward Colorlogic, promoted as programmable (it's not)* but it does enable me to switch thru various pre-set programs and many of those programs produce subtle shades of color that are evidently less luminous. White, blue and green seem to give off the most light. Red, lavendar and a few of the other modes ("sunset" e.g.) are much dimmer. Intellibrite may have similar capability, but research this first. If so, this might solve your problem. You can't employ a dimmer with the Hayward LED light.*
    • EDIT * Lights can be programmed and brightness adjusted on the PS-8 when an AQL-COLOR-MODHV controller board is added to the system. END EDIT
      Edited by Greg 10/24/2009 10:38 AM PDT
    __
    Mar 2007
    San Rafael, CA USA
    12,082
    Here are 4 pics of the pool at night with the lights on shooting at different angles (the last one is the same as the third one but with a shorter exposure time). My camera is not great for such night shots.
    PoolNight1
    PoolNight2
    PoolNight3
    PoolNight4
    Richard
    Hijack!
    Richard, if it was not for your cleaner hose floating around, I would swear we were looking at an empty pool!!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks. If it wasn't for the windy day when I took this daytime picture the pool would look even clearer. In person, the floor drains are very sharp and visible even at a distance and angle and the pool is 6 feet deep. This is with a cartridge filter, not even DE. The pool cover helps keep most junk out of the pool and that surely helps, but proper water chemistry is really the most important -- but y'all knew that already. These photos are from this year so after adding 50 ppm Borates which gives an extra sparkle to the pool.
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by chem geek
    Show off!
    Did you design this pool? I noticed what I thought was an interesting element -- the ramp. Was this installed so you wouldn't have to traverse steps while exiting the pool? When my mother visits she has a hard time negotiating the 3 steep stairs I have in my 4' shallow end. In twenty years (or less) I'm going to wish I had that ramp!
    __
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, we had the pool built and had the ramp explicitly designed into it (we used Janssen Pools and they were excellent). There are also metal bars (you can see those in some of the night photos). These elements are for my wife who had polio as a child with one leg affected so needs a smoother ramp entry instead of stairs. The bars are for exercise. We keep the pool warm (usually around 88F) as she uses it for a therapy pool, exercising almost every day (in the winter she uses a local indoor community center pool). Fortunately, I prefer the warmer water as well.
    Aug 2009
    North Central Texas
    1,358
    Thanks in advance
    Brentr, I sent you some pic to your posted email address.
    Thanks in advance
    I'll answer that too. Definitely! With the ColorSplash you can choose just about any color which also affects brightness level. The instructions tell you how to do this. Basically you get it into one of the color changing modes (any changes you want to make are controlled by how many seconds you go between switching off then on again) then when you get the exact color and/or brightness, you switch the light off for 2-4 seconds, then switch back on and it will stay that color. After the light is turned off for the night the next time it is turned back on it will stay on the color/brightness you had it on the night before. There are blends of colors so you can get just about any color and or brightness you want. For instance, the blue changes in brightness depending on how much white is blended with it. There is a very nice violet color that, I think, combines the blue and red between full color changes. The LEDs, when changing between colors, can change abruptly from one color to next or do a gradual color blend between colors, depending on what color mode you put it in to.
    Again, and I'll say it in another way, you will be shocked at the lack or blare/glare with the LED light bulb.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Okay, I had to take off the blue lens cover because the duct tape I had covering the top half of the lens was falling off. I thought I would post a pic and you can see that the glare is very strong. The second pic is taken from inside our screened room and the glare is very strong. All pics were taken with the flash off. I am still trying to decide what to do
    Any other thoughts would be appreciated.
    Thank you for your direction and support[attachment=1:1ms8ri67]DSCN9046 copy.JPG[/attachment:1ms8ri67]
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Thanks to all for your input, Pollyvue, geekgranny and chem geek. I bought an intellibrite from ebay. I could not resist as the price was very very irrestible and very very right. Got it on friday and installed it yesterday. It is better than sliced bread The colors and light shows are awesome and rich. How stupid I was not to have done this during my pool build. Everyone ]who has a pool needs to have some sort LED in their pool. It definately enhances and invites night time entertaining. I was very surprised to see no glare with the sheer descent on and very little glare with it off. I am going to add a second light switch placed in the screened room and I am going to look into upgrading to the Intellibrite light switch controller.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Brentr, I've always wanted to post this emoticon:
    Please don't neglect to post pics with your new intellibrite.
    Thanks!
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by no-mas
    Thanks!
    Ditto...... So glad you are pleased.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Okay this pic is with the intellibrite in the blue mode. The comparative pic is the first pic in this thread. I am hoping that you can appreciate less glare and the color is richer and deeper. I guess what I am trying to say is that the light is softer on my eyes. In other words when I look at the pool my eyes do not automatically look at the light as compared to when I had the incandecent light. I hope this helps and that you understand what I am trying to convey.[attachment=0:235lifbs]Copy of DSCN9127.JPG[/attachment:235lifbs]
  20. Back To Top    #20
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by geekgranny
    Thanks!
    Alice, I'm easily amused!
    Brentr, It looks great. I totaly understand what you are after; the glare on your other photos looks pretty bad. How do you like the other colors and the light shows?
