Thread: What to expect from my solar heaters
    Mar 2007
    Virginia Beach
    272
    I have (2) 20ft x 2ft solar panels hooked up to 6000 gal fiberglass pool. I use these in the spring and fall to extend the season. My question is: Does anyone know if solar panels will/can get a pool hotter than the normal daily ambient temperature? Avg temps in Virginia Beach right now are mid to upper 70's and I really like to get the pool temp up to about 80 to get in. I have a cover on it. Is it time to give up for this year?
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: What to expect from my solar heaters
    Quote Originally Posted by keithw
    Although technically possible, with 80 sq ft of panels, increasingly short sun exposure combined with cooler tempertures I would think it is unlikely that the pool temperature is going to climb into the 80s. Depends on other variables, too, of course, such as at what time of day and how long the pump runs, angle of panels relative to the sun and overnight lows, the latter two factors contributing to the average ambient temperature you mentioned. Recommend checking the forecast for your area; if avg. day/night temperatures will climb steeply during this next week, wait a few days; else, SWIM NOW!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Vero Beach, FL
    462
    It depends greatly on two things - how much sun is hitting the panel and if you have a cover or not. With good sun during the day, my solar is heating the pool 4-5 degrees right now (south Florida). However, because I don't have a cover, it looses 8 at night when the temps dropped to 56 at night. So there is no way I can keep up without a cover. Then, we had 2 days of overcast and rain, coupled with the low temps, so the pool dropped even lower. I'm at 74-76 right now. Today is sunny and high in the 80s, so it should be around 78-79 this afternoon. By contrast, one neighbor with solar and a blanket was able to stay in the mid 80s this past week, while another neighbor with no solar is at 72.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
