Results 1 to 15 of 15
Thread: installing New equipment in Pool with a lot of Green Algae
    Oct 2009
    Concord,CA
    6
    Hi, we are going to replace are 30+ Year Pump,Filter,Heater system with Pentair WhisperFlo ,Pentair Clean & Clear Plus Filter CCP420 and Pentair MasterTemp Ultra-high Performance Gas Heater we have a bad Green Algae problem, can the Algae damage the Pentair CCP420 Cartridge Filters. We have tried shocking the pool but are Pump and filter does not work very well any more. Any help would be appreciated
    Thanks
    10K gallon IG Fiberglass (Viking); Jandy AE1500 HP; Hayward CA4025 Cartridge Filter; Hayward CL200 Automatic Chlorine Feeder; Solar Blanket; Hayward 1 HP Super Pump; Hayward Aqua-Rite SWG (T-3 cell)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: installing New equipment in Pool with a lot of Green Algae
    No you'll be fine, just keep an eye on your pressure gauges etc. Algae can technically damage vinyl but chemicals are much more likely to do damage.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    30,400
    QC,
    Welcome to the forum. What city and state do you live in? (How much swimming do you have left?)
    Oct 2009
    Concord,CA
    6
    Hi, Thanks for the help. I was thinking of using Polymer Algaecide and would it be ok to Shock the pool that evening, using 2 LBS per 10,000 gallons? Also are pool is in Concord, CA not planning to swim to much more.
    Thanks
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by QC
    Welcome to the forum, QC
    Would hesitate to recommend use of an aglaecide before knowing a lot more about the current treatment and most recent test results for your pool. (Current levels for pH, FC, CC, CH, TA and CYA. If you have these numbers, please post them.) You may already know that liquid chlorine or bleach can be a very effective tool for shocking your pool, and nothing else is added to the water that you have to deal with later on. If you have a few minutes, please take the time to read these two short articles:
    pool-school/defeating_algae
    pool-school/shocking_your_pool
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Oct 2009
    Concord,CA
    6
    Thanks for getting back to me. Can you recommend a good pool test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    TF Test kits' TF100 - the link is on our home page. Otherwise the Taylor K-2006, purchased online is your best bet. It's VERY unlikely you will find a recommended test kit in stores.
    polyvue's Avatar
    Aug 2009
    1,215
    Lots of folks here use the TF-100 and possibly an equal number use Taylor K-2006 or Leslie's FAS-DPD Service Test kits (be forewarned that Leslie's stores don't always have this in stock.) All are priced at less than $100 and will last a long time. Here's a link that discusses relative merits of each:
    pool-school/pool_test_kit_comparison
    __
    Oct 2009
    Concord,CA
    6
    Thanks everyone for the help I will call up Leslie’s for the test kit. The one I have is a very basic one but I did take some levels the first is FC is about 2.0 and the PH is 7.8 not sure what I should add to the pool for the algae
    polyvue's Avatar
    Aug 2009
    1,215
    The easy answer to your question is... chlorine! But post test results first and the people here can help you through it. BTW -- Be sure the Leslie's kit you purchase contains the FAS-DPD chlorine testing components... not all of theirs do.
    __
    Jan 2009
    Cupertino, CA
    1,966
    That's easy, more chlorine. You have algae because there isn't enough chlorine in the pool. It's hard to know how much you need without some other tests, but bringing your FC up to 10 would have to help and would not harm anything (except the algae).
    What kind of chlorine do you use? (The ingredient, not the brand name.) Around here we recommend "liquid chlorine" aka sodium hypochlorite, better known as "bleach." Regular unscented bleach works great and is cheap and easy to find.
    Keep posting your progress, somebody's almost always around to cheer or advise.
    --paulr
    [And that polyvue keeps beating me to the punch...]
    BBB "Intermediate Swimmer"
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,048
    Paulr, I did not know that regular bleach from the store would have much effect on bring up FC and also kill the algea. Can you do this even if you have a SWG?
    Thanks in advance
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Quote Originally Posted by Brentr
    Thanks in advance
    Not PaulR, but YES!! In fact, we recommend using bleach or liquid chlorine to shock your SWG pool!!
    Bleach is a lower concentration (usually 6%) of pool store liquid chlorine (10-12%). Shop around a bit... some folks find it is more cost effective to buy the LC, and in some areas, bleach is the better deal!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Jan 2009
    Cupertino, CA
    1,966
    In 5775 gallons, one small (96 oz) jug of 6% bleach (e.g. Clorox) will bring FC up by about 8.
    (According to the Pool Calculator.)
    If you have an SWG, it seems to work best to use that for maintaining an FC level, but for shocking you are better off using bleach (or whatever) to bring FC up. That way the level comes up right away, you're not waiting on the SWG.
    --paulr
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,048
    Paulr and Mermaid Queen, thank you for this info. I do not have any numbers to post yet, however I have noticed some light mustard colored algea and I suspect that it is due to low chlorine. I thought about shocking it however I did not know what kind of schock to use. The water is crystal clear and the PH rises every week so I put in about 20 oz of muratic weekly. Last month I took a water sample to Leslies and the numbers came back perfect.
    I will post some numbers later.
    Thanks you for your direction and support
