Thread: O-ring lubricant
    O-ring lubricant
    My pump basket o-ring is pretty dry, in fact it whistles a slight bit when the pump is first shut off indicating it is letting a bit of air in. What do I lube this oring with?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    30,414
    Re: O-ring lubricant
    Pool stores carry a lubricant specifically for it but if your sucking air that much, it probably is mis-seated in the groove or it needs replacing (perhaps even both). A thorough visual inspection will probable reveal to you what the issue is.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    jack's lube is a brand name we use, ( it feels like vaseline but it doesn't change viscosity with temperature change like vaseline) but make sure you listen to what duraleigh said.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Aladdin's Magic Lube II w/ silicone ftw.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Though vassoline was mentioned - PLEASE DON'T EVER USE IT ON YOUR POOL GASKETS!
    Like any petroleum based product, it will RUIN the gaskets!!
    Again, welcome here, I know we'll be able to let you properly care for your pool, less expensively
    Luv& Luk
    -Ted
